2016 front wheel on a 2001 Electra glide
Old Apr 14, 2021 | 12:27 PM
pipeguy's Avatar
pipeguy
Stage IV
Default 2016 front wheel on a 2001 Electra glide
Hi guys couple of questions, can i remove my bearings and axle sleeve from my 2001 and install on new rim, its a 19x3 from a 2016 street glide special wheel. bearings were just replaced at end of last season on my 2001 wheels. that way i would retain the 1" axle. also is here any caliper adaptor to retain my oem calipers with the 11.8 rotors or will i have to get a set of brembos and mount them directly on my fork lowers to work with that set of rotors. Tried search bar but coudnt find nothing about possible bracket. thanks in advance
Old Apr 14, 2021 | 04:43 PM
EVOrider's Avatar
EVOrider
Don’t skimp out on the Brembo calipers after all that work. Much more braking power.
Old Apr 14, 2021 | 07:19 PM
rizzo's Avatar
rizzo
Get the rotors turned down to 11.5" , see the PM I sent you detailng the swap.
Old Apr 15, 2021 | 07:35 PM
twistedcherokee's Avatar
twistedcherokee
I have a 2013 Street Glide front & rear wheel on my 1999. You can get the 11.5” rotors with the bigger center hole. If you go with the bermbo brakes you can run the 11.8” rotors.
Toby
Old Apr 15, 2021 | 07:38 PM
multihdrdr's Avatar
multihdrdr
Toby
Doesn't apply ... He has an "Enforcer" with a "Spoke Mounted" rotor NOT "Hub Mounted"
pipeguy
Wheels/Tires
Apr 13, 2021 10:29 PM
Njavier03
Wheels/Tires
May 29, 2020 08:20 AM
StreetBobPhelps
Apr 24, 2019 01:55 PM
03electraglide
Feb 19, 2013 06:09 PM
Dirknar
Dec 5, 2011 07:00 AM
