DTC U0125: Lost Communication With Multi-axis Acceleration Sensor Module
The cause of the condition may be an issue with the Electronic Brake Control Module (EBCM)
Does your brake light come on when you pull the front brake lever? If yes, check the fuse for your ABS - if good, check for pinched wires for your front brake and/or a connector that didn't get connected when you installed the new bars.
The brake lights do come on when I pull my front brake lever. They're supposed to correct? I'll definitely check the fuse and wires though. I checked all my lights and turn signals, They're all good and working. I'll definitely check the wires and fuse. I appreciate it brother.
Yes, the brake lights should come on when you pull the brake lever.
Well taking bike for 1000 mile service next Friday. They're gonna check out the bcm code u0125. They told me it may not be covered under warranty since I have after market handlebars. Well f#$% me! This experience is going great. Can't wait to buy my next Harley!!!!!
