Engine Guard Lower fairing relocation on 2018 Street Gide??
Old May 1, 2021 | 06:10 AM
DaveM1070's Avatar
DaveM1070
3rd Gear
Default Engine Guard Lower fairing relocation on 2018 Street Gide??
Just wondering if the engine guard can be moved ahead a few inches which would result in the added lower fairings being moved ahead so I can add the extended brake pedal
Old May 1, 2021 | 07:40 AM
GTK's Avatar
GTK
No,as far as any aftermarket or factory kits, there is nothing out there that I know of. You could probably cobb something up if you were determined enough. Another problem is when lowers are moved forward,you have a clearance problem with front end on full lock turns.
Old May 1, 2021 | 08:45 AM
beary's Avatar
beary
I’m sure you could make brackets to move the engine guard, I think you would run into several unforeseen alignment issues. As was said, full lock turns are tight is it is.
Ashnic
Milwaukee Eight (M8)
Jan 18, 2020 01:19 PM
GuitarKidd
2014-2024 Touring Models
Apr 17, 2019 07:07 PM
Groundhog143
Touring Parts
Jan 23, 2013 07:58 AM
mimo
Jul 14, 2009 08:31 PM
ffchadbo
May 29, 2007 10:55 PM
