vibration
Old May 3, 2021 | 07:45 PM
jobo3800's Avatar
jobo3800
6th Gear
Default vibration
2005 ultra and i have a vibration in my floorboards ( can feel in my feet) while riding at road speed,it is while accelerating or decelerating but when you pull the clutch smooth as silk. ??
Old May 3, 2021 | 08:04 PM
dawg's Avatar
dawg
How’s the engine mount look?
Old May 3, 2021 | 08:26 PM
btsom's Avatar
btsom
No indication what you have already looked at , and what you haven't. If you still have the factory front engine mount, it is 16 years old and has probably had oil on it since the first oil change It may be "decomposing" from long term oil contamination. Another candidate could be the top or bottom engine locating links. There is supposed to be a rubber cushion inside each rod end. If any one of those has cracked and come out, you would be getting metal to metal contact with each engine vibration. Also check for any exhaust part touching or being very close to some part of the frame or foot board. If your bike is like my 08 Road King, there is an exhaust pipe bracket behind the rear cylinder. If any part of that bracket supporting it is loose you might feel that metal to metal contact in the frame. Have you done anything to the bike recently that involved the exhaust system or the brackets supporting it? The rear muffler support brackets should have rubber isolaters. If either or both are missing, that could be your problem. Perhaps others will add things I didn't think of.
Old May 3, 2021 | 09:15 PM
jobo3800's Avatar
jobo3800
6th Gear
i will look at mounts and locating tabs. all exhaust looks good including rubbers at tear and all brackets. etc. haven’t done anything to the exaust others have road it and say they dont feel anything but i do. thanks for the input
Old May 3, 2021 | 10:53 PM
Taxgod4u's Avatar
Taxgod4u
Had a new to me used FXD that would vibrate and make my shin bones uncomfortable if that makes any sense, nothing in the seat, just the pegs. Fixed it by properly adjusting the spark timing. It was a long time ago but I think it was too advanced.
Paul mitchell
Jul 25, 2017 12:55 AM
kdtahiti
Jun 5, 2011 04:49 PM
wareever
11
Aug 17, 2010 09:11 PM
sbergerson
Aug 10, 2010 11:56 AM
smokey27b
Jun 19, 2009 10:53 AM
