Brake Fluid change
Old May 12, 2021 | 03:18 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by corvette1
Thanks for all the input,
Brake fluid was changed last July, i live in central Fl. 3000 of the 6000+ miles were on a trip to Arkansas running hard for 8 days.
Okay, so 10 months. It should be tested every 12 months and flushed as needed. So, the dealer was probably right that it needed changing again.
Old May 12, 2021 | 03:30 PM
Uncle Larry's Avatar
Uncle Larry
OP ... look up "hygroscopic" it may clear up some confusion
Old May 12, 2021 | 03:41 PM
Beachbumcook's Avatar
Beachbumcook
Guys…. The poster’s original post stated that it’s only been 2 weeks and several thousand miles since his brake fluid was changed!!
No way his fluid went to 3% moisture in 2 weeks of riding!! If it did, I suspect he would have major brake related issues… which he did not state he had.
No way freshly flushed brake fluid gains 3% moisture in 2 weeks in a sealed system.
Old May 12, 2021 | 03:48 PM
GalvTexGuy's Avatar
GalvTexGuy
See post #7.
Old May 12, 2021 | 04:18 PM
skratch's Avatar
skratch
okay, slow down y'all and take a deep breath. first, he didn't say he had it done two weeks ago, he said he's going on a trip in 2 weeks. also, the brake fluid should be changed whenever it gets saturated with water, regardless of the time. per the manual, the moisture content should be checked at every 5k service. i bought a moisture meter and check mine every time. i did not make it to 2 years before it needed changing. i had it changed at 10,000 miles, which correlates to 18 months of riding. (usually average 10k per year, but this last year was not normal).
in the end, it's up to you to decide your comfort level. do you want to wait until after your trip and check it again, then have it done? or just pay the $175 and have it done before your trip so you are sure you've got fresh fluids before you go? if you wait, it isn't like the bike is going to explode if it hits the 4% threshold during your trip.
Old May 12, 2021 | 04:19 PM
Uncle Larry
Reading comprehension helps
Old May 12, 2021 | 07:01 PM
dawg's Avatar
dawg
Absolutely normal IMHO. Change every two years or when it is 3%. Under the conditions you list and the time frame, totally possible and better safe than sorry. If you’re worried about dealer taking advantage, do your own maintenance and it will be a non-issue.
Old May 13, 2021 | 06:21 PM
cwsharp's Avatar
cwsharp
The 50,000 mi. service says every 25,000 mie.
Old May 13, 2021 | 06:34 PM
harkon's Avatar
harkon
Do it yourself. Speed bleeders make it stupid simple.
Go here
http://infotechmercenary.com/shop/
and you can do a proper service center flush. Get to where you can change your own wear parts and the dealer won't be stealing any more of your money ... for brakes at least.
Old May 16, 2021 | 01:20 PM
cwsharp's Avatar
cwsharp
Be careful with speed bleeders... I bought a set once (of recommended ones) and had to re-thread the female threads on the caliper and the male threads on the bleeder.
