Power Vision Question
Old May 17, 2021 | 08:38 AM
touchdown's Avatar
touchdown
First thing the bike only pings lets say if im do 60 mph and want to accelerate to 70 mph little ping but stops right away. So I did check and change plugs, checked for exhaust leaks. I could most likely ride this way foe ever but I like my **** tight. Talking to the tuner I use he said a tune out of the box works some of the time but most likely it off. So I think I will take it to him and let him do his thing. Thanks all for the input.
Old May 17, 2021 | 09:02 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Acceleration enrichment is my first thought and found this
MegaSquirt Acceleration Enrichment Tuning - DIYAutoTune.com
Old May 17, 2021 | 10:05 AM
touchdown's Avatar
touchdown
Ya that's the line I was thinking.
Old May 18, 2021 | 10:07 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
When was the last time you changed the fuel filter?
Old May 18, 2021 | 03:40 PM
touchdown's Avatar
touchdown
Will be changing the next service in 2000 miles It will have 25000 on it then.
Old May 18, 2021 | 03:55 PM
lightweight bob's Avatar
lightweight bob
Default Redline motorcycle fuel system cleaner
Most fuel system cleaners are junk but this one really works - https://www.redlineoil.com/complete-...er-powersports
Amazon -
Amazon Amazon
This would be my first shot.
Old May 18, 2021 | 04:25 PM
BikeEnthusiast7's Avatar
BikeEnthusiast7
Stage III
So I swapped my stock pipes and air cleaner on my 883 Iron,
which is why I bought the DynoJet Tuner. I autotuned the bike by riding 20 mins....
loaded that map...rode another 20 mins....loaded that map...and then did the same
thing one more time. The bike runs fine, but when I 1st start the bike (cold) it
sputters a lot and almost wants to stall (unless I throttle it a little). After that
it runs fine. Any idea why this may happen at every cold start?
DynoJet Power Vision Tuner
Old May 18, 2021 | 04:53 PM
Dseago1969's Avatar
Dseago1969
So a couple things I want to comment on. @BikeEnthusiast7 20 minutes? Really? Not long enough. Ride it for at least 45-90 minutes. Also the auto tune doesn’t do much at idle. Look elsewhere, maybe a loose/poor connection from your changes.
@touchdown either use the bike or the power vision to read the codes. I prefer the PV. Something is different. Heck even run it connected and ride for a while and watch temp and other items. Tunes don’t suddenly get stale. Start with pulling your air filter and cleaning it and while it is out of the way, poke around a bit to make sure everything looks right.
psoff
13
Oct 2, 2020 04:02 PM
semiret
May 4, 2015 10:09 AM
goose222
Apr 5, 2015 11:14 PM
hockey8787
Aug 25, 2014 10:28 AM
whynotf75
Jun 12, 2014 08:55 AM
