Tour Pack
Old May 22, 2021 | 10:29 AM
Terry L Brown Sr's Avatar
Terry L Brown Sr
6th Gear
Default Tour Pack
I bought a tour pack mount for a king tour pack for my 03 police road king. With the pack on, my bags won’t open, how do I raise the pack up? will it still be stationary, and help please would be great
Old May 22, 2021 | 11:08 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Outside of using spacers to pick the pack up, your choice is replacing the bags, which was one of the first things I did with my bike
Old May 22, 2021 | 11:13 AM
PoCoBob's Avatar
PoCoBob
I put a pre Rushmore tour pak on a Rushmore bike. I went to Walmart and bought a 3/8" nylon cutting board and trimmed it to fit between the tour pak and mounting rack. The Rushmore's mounting rack is flat so it worked fine. I'm not sure what shape yours has.
Old May 22, 2021 | 12:49 PM
CrimSonami's Avatar
CrimSonami
My latches rubbed with mine in solo position. Bought some 1/2" aluminum channel and longer bolts. Cut the channel to create 2 rails and match drilled the bolt pattern. Added some isolation washers to reduce the stress on the ABS. Lifted it just enough to a clear.
Old May 22, 2021 | 01:07 PM
Harfar's Avatar
Harfar
Any type of spacer on top of the tour pak rack will work, the idea from POCOBOB was excellent! Cutting board wont rot or warp.....
MedicUSA
May 11, 2017 03:44 PM
Eagle240
Jun 3, 2015 03:22 PM
BadX
Mean City Cycles
Apr 17, 2013 11:47 AM
timn
Jan 28, 2012 04:57 PM
BadX
Mean City Cycles
Oct 9, 2011 08:18 AM
