Handlebar adjustment '17 Ultra
Old May 30, 2021 | 05:03 PM
BrianH's Avatar
BrianH
Default Handlebar adjustment '17 Ultra
Ok...... Title says it all. How do you adjust handlebars on the '17 Ultra???
Old May 30, 2021 | 08:58 PM
GalvTexGuy's Avatar
GalvTexGuy
Buy a service manual?
Old May 30, 2021 | 11:29 PM
BrianH's Avatar
BrianH
Good 1 GalGuy!! i'm the 1 who usually says that. But my Shop/service man. only shows how to adjust on a RK.Thought there mite be another, easier way. Yea, i just need to raise them up about 1/4 "
Old May 31, 2021 | 06:44 AM
TnFatboy's Avatar
TnFatboy
You can access the two rear riser bolts (they are 1/4” Allen heads, so you’ll need a long bit to them ) by removing the plastic auxiliary switch panel under the ignition switch. Usually loosening those two bolts will be enough to be able to move your bars. It didn’t work for me, I ended up having to remove my outer fairing and more. There are several good YouTube videos if you have to go that far.
Old May 31, 2021 | 10:07 AM
Wolfmiester's Avatar
Wolfmiester
YouTube the topic. Very simple, but you may want to upgrade your bushings and clamp while you are at it.
Old May 31, 2021 | 09:34 PM
BrianH's Avatar
BrianH
Ok, Thanks for all the help guys!!!
Harley42
Dec 17, 2011 01:51 PM
7125
Sep 24, 2010 03:58 PM
rhinoevans
Apr 26, 2008 11:36 PM
DaveZ
Sep 27, 2007 03:02 PM
sinsee
Apr 23, 2007 02:28 PM
