Should i replace stock head pipes
Old Jun 8, 2021 | 11:47 PM
Chad1200's Avatar
Chad1200
If you already have slip-on mufflers, you can get a head pipe kit from Fullsac Performance that will work with your OEM heat shields. Personally, I've never used them but lots of guys on here have.
Old Jun 9, 2021 | 09:24 AM
bobter3's Avatar
bobter3
Another option is finding a stock head pipe already de-catted. http://www.wildpigpipes.com/Store1.html has them for $150 and you can keep your stock pipe. This is the route I took and works/runs great.
Old Jun 9, 2021 | 11:03 PM
n of 1's Avatar
n of 1
Go for it, dumping that cat via removal or replacement is worth it in my book.
Old Jun 9, 2021 | 11:56 PM
Old_Bikes's Avatar
Old_Bikes
I have the Fullsac headers on my Road King and Limited. It is a good, quality pipe. I also installed the Fullsac cores in the stock Limited mufflers, as I did not want them loud and had read good things about them. I found they worked very well for my set up.
Old Jun 29, 2021 | 10:53 AM
Tate Richards's Avatar
Tate Richards
3rd Gear
Been riding my 14 Road King for a little over 3 years, so I have a good baseline on how it performs. Basically stock other than Cobra slip on mufflers and a K&N air filter. Last weekend I drilled out/removed my cat and I'm amazed at the difference in throttle response and love the way it sounds now. Less heat on my right leg while sitting at stop lights is another benefit. My only regret is that I didn't do it a long time ago. Been thinking about buying a tuner, but not sure if I really need one. Time will tell I guess.
Old Jun 29, 2021 | 01:28 PM
Dseago1969's Avatar
Dseago1969
@Tate Richards you definitely need a tuner or Dyno. You are passing more air through an engine that has an ECM that already has a lean AFR.
Tuning is more that just performance, it is also engine longevity. BTW you think you are happy with cooler now, richer mixture also runs cooler.
Old Jun 29, 2021 | 03:21 PM
LazySundays's Avatar
LazySundays
Originally Posted by nordhaven
I live in Canada, nobody looks or cares about catalytic converters on bikes...just saying.
Not necessarily true. I've known guys to be pulled over and had their bikes checked in Ontario. Usually on roads into or out of events.
I don't think it happens often but you can never say never and the fine is no fun.
Old Jun 30, 2021 | 08:20 AM
booze hound's Avatar
booze hound
I recently went with a Fuel Moto header, S&S slip on’s, stealth Big Sucker and PV tuner. All items purchased from Fuel Moto. Losing the cat will help with heat and I’ve been very pleased with the new set up.
I was on the fence regarding getting the new header but I’m glad that I did. Easy swap and the guys from Fuel Moto are very helpful. Good luck with your decision
Old Jun 30, 2021 | 10:02 AM
pyuchem's Avatar
pyuchem
so you still have stock header ? My 2016 street glide is all stock. No slip ons and stock breather.
just wondering if I can just take out the catalytic converter and leave everything else stock for getting rid of heat. Next year I’ll get new slip ons, breather, PV or something else and dynoed. TIA guys.
Old Jun 30, 2021 | 01:31 PM
pyuchem's Avatar
pyuchem
Following up on my question above. If it's ok just to take out the catalytic converter if my bike is still stock. I called local muffler shop to check if they will do it and I was told it's against federal law. He won't be able to do that.
