throttle by wire issue
Old Jun 11, 2021 | 10:20 AM
WacoWayne's Avatar
WacoWayne
1st Gear
Default throttle by wire issue
I replaced the main power fuse and voltage regulator/rectifier. Started right up. Went out yesterday cranked it, started right up again. Now it idles way to high and throttle does not work. I normally take it to the shop to get it fixed. Money getting tight and hoping to save some. Any help you guys and gals can give me will be greatly appreciated.
Old Jun 11, 2021 | 04:19 PM
dawg's Avatar
dawg
Any codes?
Old Jun 11, 2021 | 07:18 PM
Dseago1969's Avatar
Dseago1969
That sounds like limp mode. Search and check every connector you touched or is in the area. Plug and unplug a couple times, add dielectric grease and plug in firmly.
Check the codes, write them down and then clear them.
Anthony Walker
Electrical/Lighting/Alarm
Mar 29, 2020 05:06 PM
FireHogRider
18
May 4, 2017 11:37 AM
Deadstroke
May 1, 2016 05:17 PM
anicely
Sep 4, 2013 10:04 PM
Taterdog
May 14, 2007 10:42 PM
