Electrical oddities
It is throwing several problem codes, and I was able to figure out how to capture them...
U1097
U1255
U1300
U1016
All look related to connections of some kind. I am sure it isn't going to be an easy one to diagnose, and I don't really have the tools to do so, but thought maybe someone had experienced these symptoms before, and maybe it was something specific. Worth a shot before I take it to the local dealer for a once over...
TIA
next thing I would consider is a lot of the codes are low data to ECM and low data from Speedo. I think the u1300 or u1016 causes the red key to light up. I would be checking the connection to the ECM and wires running to it. The ECM is located under the left side panel and held on by a couple Allen screws. It it very important to pull the fuel pump and ECM fuses before disconnecting the ECM. Disconnect and reconnect a couple time, add a little dielectric grease and reconnect. Put it all back together and see what you get.
slim chance you could bring it back to life, but it's highly unlikely.
Did you ck any voltages while running and off andowith key on?
