Im looking to start buying the parts and pieces for a winter build. Besides the obvious (124" kit, TB, injectors) what else will be needed? Ill be running a 10.75 compression so my RS 468 will be used. Let me hear your thoughts on this so I can get some more stuff.
With my 124" upgrade, I added a Barnett HD spring and an AIM variable pressure plate... It worked well with stock clutch & compensator at 135HP & 151TQ.
The stiffer spring got to be annoying in SoCal stop & go traffic, so I added a Muller hydraulic clutch slave. It was an excellent addition. For the hell of it, I also added a 32T solid engine sprocket.. all is still holding together well....
If you are a ride-it-like-you-stole-it type, you may want to look into a better clutch and clutch basket...
