Not sure what is happening, when I first start bike I have no warning lights on. After 20 minutes or so of riding I get check engine light, abs and red security lights. I lose all button functions on left side thumb controls. When I am able to check codes( hard to do when thumb controls don't work)they are random and have no matches when looked up.
2015 Electra Glide Ultra Classic
Vance and Hines tru-duals(changed over 2 years ago)
new battery
Thanks in advance,
Started about 2 months ago... before replacing battery.. at 1 in 5 times I would ride.. I keep the bike on a tender so battery is always fully charged. I have checked and rechecked the battery connection, my next check is the grounds at voltage regulator ( once weather clears. I will have codes for everything (ecm,bcm,radio,security ect)
Well it finally cooperated with me and I was able to retrieve and reset codes.. see list below
ECM, U0001, U0141, U0156
BCM, B2260, U0121, U0141
SPEEDO, U0001, U0121, U0141
ABS, U0100, U0140, U0156, U1042, U0001, U0003
RADIO, U0002, U0141, U0001
All from a 30 minute ride, voltmeter( factory in fairing) shows 12 1/2 to 13 volts while riding. It starts fine anytime I stop and shut it off. I have started following the trouble shooting sticky as previously suggested. But am open to a short cut...lol... my old behind don't have a lift and with my bad back I can only do so much at a time..
Majority of all the codes are lost communication. What would cause that?? I have not changed anything in a while. I have my gremlin bell.. might need a new one lol!!!
