Primary fluid quantity
Old Aug 6, 2007 | 04:49 PM
Atomic Bagger's Avatar
Atomic Bagger
Default Primary fluid quantity
For the TC88 primary, and the Evo for that matter, the book says it'll take approximately 32 ounces of fluid. Has anyone else had to put up to about 40? I fill it while it sits on my bike jack, meaning level, just until it gets to the clutch spring. It was like that on my Evo also.
Maybe the bike is leaning forward a bit on the jack which would add a few ounces, but 8 extra seems too much.
Sounds and shifts fine.
Thanks
Old Aug 6, 2007 | 05:13 PM
Blackisfast's Avatar
Blackisfast
Default RE: Primary fluid quantity
I think 38 is what is actually called for...just enough over a quart to screw up your fuids stash.
Old Aug 6, 2007 | 05:15 PM
xxxflhrci's Avatar
xxxflhrci
My 2000 owner's manual says approximately 32 oz. I just dump a quart and don't worry about it.
Old Aug 6, 2007 | 07:52 PM
Spartan's Avatar
Spartan
Mine took 38 oz
Old Aug 6, 2007 | 07:54 PM
Mick's Avatar
Mick
My 2006 factory manual says 32 oz , so that's what I used.
Looks just like the picture in the service manual also at 32oz.
Looks like the bottom gear teeth on the clutch are just submerged.(on the jiffy stand)
Mick
Old Aug 6, 2007 | 08:09 PM
Neckball's Avatar
Neckball
https://www.hdforums.com/m_1693879/tm.htm
Old Aug 6, 2007 | 08:32 PM
Spartan's Avatar
Spartan
ORIGINAL: Mick
Mick
With the bike level, you should be able to add another 6 oz. This is how you check the primary fluif level.
Old Aug 7, 2007 | 06:12 PM
kurtlange's Avatar
kurtlange
ORIGINAL: Spartan
but why??
manual sez 32 oz [1 qt] so that's what i dump in.
Old Aug 7, 2007 | 08:26 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: kurtlange
ORIGINAL: Spartan
but why??
I'll bet if he lays the bike over on it's right side, he can get a gallon in.
Old Aug 7, 2007 | 09:15 PM
skratch's Avatar
skratch
don't know about earlier, but 07 says 38 oz.
