I was cruising my 96 Road King this past Sunday when all of a sudden I lost all power to my bike. I had to get towed home ($225!!). I pulled the battery and repaced it with a new one and I rode over to my friends house. When I went to leave, the bike wouldn't start. Dead battery again! Afriend
told me that it probably is the Regulator or stator, or both. My question is, should I first replace the Regulator and see if that is the problem. Or should I go ahead and replace both. Also, when disconnecting the regulator from that engine case <stator>, do you just pull out the plugis there something else that has to bedone. Any info would be greatly appreciated.
Disconnect the stator and run a continuity test to ground with each of the 3 leads. You'll probably find one of the leads is grounded - this time of year, we see many shorted stators due to heat, I believe. When a regulator goes, it usually over charges the battery - but, not always. My guess is it's the stator.
