Power outlet?
Old Aug 24, 2021 | 04:18 PM
gduncan's Avatar
gduncan
Default Power outlet?
Looking at the schematics for a '17 SGS, looks like it's called the Power Outlet. I call it the Cigarette Lighter outlet. Any way, my phone is not charging while plugged into the "Power Outlet". I've changed cables and plugs. I pulled the Mid Engine cover off the left side, see a small fuse block and checked the fuses. No blown fuses. What am I missing? I have not pulled the fairing apart yet...
Thank you
Old Aug 24, 2021 | 04:26 PM
dawg's Avatar
dawg
Did you actually test the outlet with a 12v tester to make sure there’s power to it? If no power, check the fuses with a meter as they can look deceiving.
Old Aug 24, 2021 | 04:47 PM
gduncan's Avatar
gduncan
No, i have not tested the outlet with a test light. I've had two sets of eyes look at each fuse and they're definitely not blown. However, I will test for continuity. Thank you.
Old Aug 24, 2021 | 04:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Check the P&A relay.
Old Aug 24, 2021 | 05:11 PM
gduncan's Avatar
gduncan
Will do… Thank you
Old Aug 24, 2021 | 05:38 PM
FlamedFXR's Avatar
FlamedFXR
There were earlier models that were actually wired opposite as far as positive/ground. Don't know when or why but it's worth taking a closer look.
Old Aug 24, 2021 | 05:44 PM
Padre's Avatar
Padre
THIS!!! They did this on my 2020 SGS
Old Aug 24, 2021 | 07:29 PM
gduncan's Avatar
gduncan
Update... Took the test light to the power outlet, nothing. Tested other spots on the bike, light lit up like a Christmas tree. My multi-meter is at work. Will bring it home and test the fuses. Thank you for all the help.
Old Aug 24, 2021 | 07:41 PM
Hoginedgewood's Avatar
Hoginedgewood
Thank you
you say small fuse box? My o6 had a larger fuse box on the other side. Maybe check your book
Old Aug 24, 2021 | 07:56 PM
gduncan's Avatar
gduncan
I'll post a picture tomorrow of the fuse block on the left side.
