New member, 0 Oil Pressure 1997 Electra Glide
Old Sep 4, 2021 | 02:34 PM
79josh81's Avatar
79josh81
It gets worse…
Old Sep 4, 2021 | 02:35 PM
79josh81's Avatar
79josh81
Now I know why my pump wasn’t spinning. 😕👎
Old Sep 4, 2021 | 07:20 PM
79josh81's Avatar
79josh81
Anyone know where the c-clip came from??
Old Sep 4, 2021 | 08:16 PM
hardheaded's Avatar
hardheaded
That kinda looks like a piston c-clip, but don't know how it would ever get there. Hard to tell from pic's though. If you can find every piece of that gear and anything else that's tore up maybe get buy with just replacing broken gear and pump parts, but you would have to find every piece. I don't think there is any snap rings in the cam chest area.
Old Sep 4, 2021 | 08:37 PM
79josh81's Avatar
79josh81
Here’s a better pic of the clip for sizing purposes. It was literally just laying in the bottom of the cam case after I removed the cover. The washer is for the breather valve gear so no worries there. I just have no idea what this clip is from.
Old Sep 4, 2021 | 08:46 PM
79josh81's Avatar
79josh81
The only gears that are tore up are the oil pump shaft gear and then the pinion gear that contacts the oil pump shaft gear. From what I can tell, I’m going to have to pull the motor to replace the oil pump shaft gear because I don’t have enough clearance to get the chewed up gear off the shaft. I removed the cir-clip from the end of the pump shaft by the gear but I still can’t get the gear out.
Old Sep 5, 2021 | 07:24 AM
79josh81's Avatar
79josh81
I literally can’t find any parts diagram that shows a c-clip of that size that’s even supposed to be in the cam case. I don’t know where it came from so if anyone has any ideas please let me know because I’m stumped right now.
Old Sep 5, 2021 | 08:59 AM
Indawynd's Avatar
Indawynd
You might find something here.
https://partsfinder.onlinemicrofiche.../showmodel.asp
Old Sep 5, 2021 | 09:15 AM
79josh81's Avatar
79josh81
Originally Posted by Indawynd
That’s the website I’ve been using for the parts diagrams and I can’t find that c-clip anywhere. Thanks for the reply though. 👍
Old Sep 5, 2021 | 09:23 AM
79josh81's Avatar
79josh81
Is that clip potentially supposed to be in this groove (where I put the arrow) to keep the shaft from sliding in too far?
