Lighting Upgrade
The way I see it, there are a few options and I'm thinking about phasing in my lighting in these three steps:
1. Upgrade with a LED Signal Conversion (like the Custom Dynamics "PREMIUM PLUG & PLAY BULLET BEZEL LED TURN SIGNAL CONVERSION KIT"). I assume these front "run/turn" lights will toss out more light than the standard HD bulbs which will help on those dark streets at night.
2. Upgrade the stock HID headlight with a LED.
3. Upgrade by adding LED passing lamps / Auxiliary lights (if needed)
Is it overkill to upgrade all three? Maybe after upgrading turn signals and the headlight I won't need the passing/aux lamps (but I always like the look of passing lamps and had them on a prior bike). Thoughts?
I like the Custom Dynamics stuff from what I've seen on YouTube and the various postings here. However I know H-D, HogWorkz and Ciro3D both have options as well. All input welcome.
Oh yea - is there any issue running a mix of the LED upgraded run/turn/break lights along with the standard HID headlight, or do these need to happen at the same time?
TIA,
-PH
You will however, have a lighter wallet. Good luck.
The white/yellow LED turn signals don't add that much light for riding but are much more visible to on coming traffic.
A good LED headlight (CD) will provide the road illumination you are looking for.
I have LED running and signal lights. I installed them because I like the way LEDs work on cars, and any decrease in load is better for the battery.
A stock High Intensity Discharge headlight is usually chosen by an OEM for overall performance. The engineers who designed the bike felt that the HID would offer better illumination over halogen. The lamp housing is usually engineered to "throw" the lighting and aim it best for visibility.
Harley does sell a "daymaker" LED headlight. I don't know how the HID or LED compare. The best thing to do since you already have the HID, is find someone with LED, and do your own side-by-side comparison. There is a lot of information online. Many articles comparing HID to LED. In the car world, HID was 1990's technology, and LED came along in the 2010's. That doesn't make LED better for you, just because it's a newer technology. Note that on the PanAmerica and Sportster S, Harley is using LED headlights.
Harley Davidson DayMaker LED cost a lot. There are other brands. Some people have had good results with less expensive LED headlights. I am using an inexpensive LED, which is fine for me. It was an improvement compared to the halogen headlight.
You may consider adding auxiliary LED lamps. Just like on a truck or jeep. This will drastically change the way your bike looks. It will also drastically change the amount of light on the road. With a little bit of custom work, off-road LED spotlights will put a lot of light on the road.
TIA,
-PH
For being seen: LED running lights and turn signals, LED center brake light, module for the rear lighting that converts the turn signals to running lights and allows flashing patterns for your brakes. I have Custom Dynamics turn signals with smoke lenses front and back, CD Probeam brake light, and CD Triple play module. They also make headlights with a halo that helps with being seen, but I am not a fan of the look, at least on my Road King.
For seeing better down the road: LED headlight will be way better than the stock (halogen, not HID) headlight. If you ride much at night (I do) then if you have the $$ go for an adaptive headlight. I have the JW Speaker, but CD has one also (I think is the same light just different branding). It shines light into the corner area that is dark with a normal LED light when you lean the bike. I was skeptical until I tried it, now would never go back to a regular LED light. If you never or rarely ride at night then a regular LED light would be fine.
Passing / aux lights throw light mostly right in front of the bike and to the side to light the ditches. I went cheap on these - Amazon special, Sunpie brand.
There is no issue running mixed. I upgraded in steps - front and rear turn signals first, then tail light, then headlight and passing lamps, then just recently the adaptive headlight.
Thanks!
-Ph
You don't need to install the LED's all at once. You can run both LED and the stock bulbs together, and add more LED's as time or your wallet allows.
But yeah, after doing this, I did not think it was that bad.
And no, I did not check anyone else for kits.
