Lighting Upgrade
The way I see it, there are a few options and I'm thinking about phasing in my lighting in these three steps:
1. Upgrade with a LED Signal Conversion (like the Custom Dynamics "PREMIUM PLUG & PLAY BULLET BEZEL LED TURN SIGNAL CONVERSION KIT"). I assume these front "run/turn" lights will toss out more light than the standard HD bulbs which will help on those dark streets at night.
2. Upgrade the stock HID headlight with a LED.
3. Upgrade by adding LED passing lamps / Auxiliary lights (if needed)
Is it overkill to upgrade all three? Maybe after upgrading turn signals and the headlight I won't need the passing/aux lamps (but I always like the look of passing lamps and had them on a prior bike). Thoughts?
I like the Custom Dynamics stuff from what I've seen on YouTube and the various postings here. However I know H-D, HogWorkz and Ciro3D both have options as well. All input welcome.
Oh yea - is there any issue running a mix of the LED upgraded run/turn/break lights along with the standard HID headlight, or do these need to happen at the same time?
TIA,
-PH
I was in the same boat in June when I bought my ‘21 SG. I replaced the stock HID headlamp with the HD Daymaker adaptive. That was a huge improvement, both in the quality of light and the throw. I also upgraded the front and rear turn signals to the HD inserts with the white halo. They do not throw significantly more light, but they look good. Finally, I added a set of CD ProBEAM fog lamps to the engine guard. That made a huge difference in being able to see the side of the road and scanning for deer. They throw a lot of light.
I live in a fairly rural area with a lot of wildlife and I need to see at night. After all these updates, I’m in good shape.
https://www.customdynamics.com/amfin...e--flhx--34316
After that, you can do the LED turn signals, which will increase your visibility to other drivers, and add passing lamps if you want, which are short-throw lights that are similar in terms of projection distance to the headlamp low beam.
All of our various options for your bike can be found here: https://www.customdynamics.com/amfin...e--flhx--34316
Thanks,
-PH
The advice to call Custom Dynamics is good advice. I remember when I did mine that it said something about being not good to run LED and standard together BUT do not take that as anything more the hear say Call!
Here is what I am running: and yes this was NOT cheep (cost over $2000) BUT I love it, and would do it again!
Going up the middle in the day light 80 to 90% of the people see me before I get to them and move over for me now
In the past, 20 years or so on a metric with standard lighting it was less then 10% AND AT NIGHT "This thing is lit" Both coming and going!
So this is my list: (Most was from Custom Dynamics)
xmc-7RD - Vision X 7″ XMC Motorcycle LED Headlight
Custom Auxiliary Lighting Kit Part Number 67800367A & xmc-45RDHKIT - Vision X XMC 4.5″ LED Passing Lamp Halo
PB-RR-1157 PROBEAM® RED RING 1157 REAR LED INSERTS WITH RED LENSES
PB-AW-1157 ProBEAM® Amber/White Dynamic Ringz™ Front 1157 LED Bullet Inserts with Smoked Lenses
PB-TRI-3 ProBEAM® Dual Intensity LED TriBAR for 2014-2020 Street Glide®, Road Glide® & Road King® Special
Saddlebag LED Latch Lightz™ for 14-20 H-D™ Touring
MAGIC-STROBES-RSG MAGIC STROBES™ RSG BRAKE LIGHT FLASHER FOR 14-20 H-D™ TOURING
CD-LPSEQ-BCM TSD Sequential Low Profile BAGZ™ Saddlebag Lights for 14-20 H-D™ Touring Models
PB-MINITL-BCM ProBEAM® Mini Add-On Taillight for 2014-2020 Street Glide, Road Glide & Road King Special
I have two sets of lights from you guys
And both sets you have discontinued now.
I bought a set of your mega Spotz this year for custom application.Paid close to $400
Cut holes in my body panel for custom lights.
So when one goes bad I’m left with holes in my body.
I tried to buy another set and was told you don’t sell them any more.
Wasnt a clearance item when I bought them if I would of known I would have
went another direction.
Another example are the lights I have custom fitted to my bag extensions.
You know longer carry those anymore.
So left with more holes if they go bad.
A heads up to customers on items
That you are going to discontinue in the future would be nice.
Everything Polaris was still advertising them for sale so I emailed them to make sure they are in stock after I talked to you guys, They got back to me and said they just found out they are discontinued.
They didn’t even know.
I guess what I’m trying to say is which ever lights you guys decide to get and what application you are using them for make sure you buy extra.
Once I narrow down the primary headlight, I'll probably get the matching Aux lights, unless there is a real compelling reason to mix & match.
Thanks,
-PH
