2002 Roadking sputtering, help
Old Oct 12, 2021 | 01:13 PM
Brock_neill's Avatar
Brock_neill
Stage III
Default 2002 Roadking sputtering, help
Having issues with my 2002 Road-king. The bike runs fine for 10-15 minutes, then once everything gets warmed up it'll start to sputter bad. When I really pin back the throttle hard I'll get a check engine light that will come on only for a few seconds. The sputtering only happens when I accelerate, but once I'm cruising I can feel a lack of power and the bike will hesitate. The bike is fuel injected and I'm suspecting a problem within the tank. I replaced spark plugs and checked battery. Heard some people talk about liner from the fuel tank that might be clogging a fuel line?
Old Oct 12, 2021 | 03:16 PM
Mr. Mike's Avatar
Mr. Mike
I don’t think you’d see the check engine light if it were a peeling liner even if you’d bikes fuel injected. It would feel like it’s running out of gas because it is. But would that alone cause the engine light? I wouldn’t think so but I’m not a wizard by any means. You can see if the liners peeling by peering into the tank with a mirror and LED flashlight. If it is you may see bits of gray liner skin floating about or laying on the bottom of the tank.
Have you done a diagnostic check for errors?
Old Oct 12, 2021 | 04:42 PM
Ironhandjohn's Avatar
Ironhandjohn
What does your air filter look like?
Old Oct 12, 2021 | 09:54 PM
Ron750's Avatar
Ron750
Do you service your own bike? When is the last time you changed your breather tube? A cracked one can cause sputtering.
Old Oct 13, 2021 | 07:00 AM
MyFavRk's Avatar
MyFavRk
How many miles ? If the fuel filter hasn't been changed out , I would do it , along with the pressure regulator and hose .
Then clean out your iac , this should be done at every oil change , place a rag inside the tb to catch all the gunk , spray the iac pintle with tb cleaner , at the same time , ign turned on , cycle the run / stop switch ( do not start ) , you'll see the pintle moving . When eveything looks clean , do the butterfly and seat .
Old Oct 13, 2021 | 08:56 PM
euchre98's Avatar
euchre98
Magnetti EFI…. You have a intake leak. That system is famous for the problem and your symptoms are exactly what it does.
Old Oct 13, 2021 | 09:07 PM
Ron750's Avatar
Ron750
2002 was the first year of the Delphi fuel injection.
Old Oct 14, 2021 | 04:25 AM
euchre98's Avatar
euchre98
my bad. I would still check for intake leaks.
Old Oct 14, 2021 | 04:59 AM
Stiggy's Avatar
Stiggy
My (earlier,) MM injection did the same thing. It turned out to be the throttle position sensor.
Old Oct 14, 2021 | 09:22 PM
hattitude's Avatar
hattitude
When the check engine light goes out, that means the active code is no longer active.... but... it will still be in the ECM as a "Historic" code.. It takes numerous engine "cycles" before the historic codes clear by themselves.....
Check your codes, and it will tell you what caused the check engine light...
