Vibrations after new head pipes help.
Old Oct 16, 2021 | 04:59 PM
steelerdude1's Avatar
steelerdude1
Originally Posted by golfblues
If you checked the bike when it was up on the jack I'm sure everything looked like it had clearance. You should recheck everything once you lower your bike onto the ground. Sometimes it's as simple as a worm gear strap bolt touching the frame or the right muffler rubbing the axle nut.
I checked everything with the bike on the kick stand. Nothing touching.
the rain stopped and the roads dried up a bit, and just took it for a ride and there is no difference from my reinstall. The vibrations/buzzing is the worst between 2000-3000 RPMs. It’s tolerable under 2K or above 3K.
I am positive that this started since the new pipes, but now I’m questioning if I have a bad rubber mount.
I guess I’m going to try to put the stock header back on to see if it goes away. That means another set of exhaust gaskets.
Very P O ’d with this, makes riding a source of stress, instead of being a stress reliever.
Old Oct 16, 2021 | 05:19 PM
flh canuck's Avatar
flh canuck
You might want to loosen all the exhaust fasteners again and then re-torque starting from the front of the motorcycle and working your way back. Harleys are can be a little bit finicky with installing new exhaust and the above procedure should work.
Old Oct 16, 2021 | 05:26 PM
TwiZted Biker's Avatar
TwiZted Biker
Different pipe & flow configuration means different exhaust pulse and harmonic vibration bands, ain't rocket science. Action / reaction.
What it is, rubbing somewhere just amplifies it.
Old Oct 16, 2021 | 05:37 PM
golfblues's Avatar
golfblues
Checking on a side stand is not the same as sitting on it straight up....All parts get closer together once you put it in a riding position and sit on it....Shocks compress and lots of spaces change.
I don't think it would have anything to do with the FP3 but you could always throw in another tune and see if it does the same thing. Or reload the stock tune just to check it out.
Old Oct 16, 2021 | 06:37 PM
steelerdude1
Thanks for the input.
I just had my buddy check all for clearances with me on the bike, and then had him sit, and I looked. Nothing is touching. Can’t hurt to change up the tune to try that before I ditch them.
It’s a hard pill to swallow having to take off something as pricy as these were, and go back to the stock ones with the cat heat.
Old Oct 16, 2021 | 07:07 PM
golfblues's Avatar
golfblues
How about a loose baffle? Bang around on the pipes with a rubber mallet....
Old Oct 16, 2021 | 07:33 PM
FunHuman's Avatar
FunHuman
I cannot believe this tread was just started. I just got my 2021 FLHTK back today (new thread later) from an SE 131 kit build with a Fullsac header pipe and Max-Cell cam. The vibration through out the bike is crazy as you accelerate. I thought the bike was going to vibrate apart as I hit highway speeds. I haven't checked for anything touching. Spoke to the builder who thought the bike ran smooth.
After taking a break riding and speaking to the builder I surmise it's just the new pipe, cam and the 30hp jump. It took me most of the day riding but I have gotten used to it.
Running Khrome Werks 4.5 with performance baffles and the vibration is that exhaust deep drum beating sound/vibration transfer to the front end. It's like a pounding as you crank the throttle.
Is the re a cure short of a little pipe?
Old Oct 16, 2021 | 10:36 PM
steelerdude1
Update:
Found some threads with people who have had similar issues on this site and other sites. Common things are what had been described here with something touching the frame or Floorboards, but I also found a few that were all tune related.
After I got home tonight, I changed the tune to the custom tune V&H gave me when I first got the tuner. It is for stock headers and my fishtail II slip ons, and was made more so to try to cool the Cat down. It is a richer tune, I can smell a difference.
it’s late, so I haven’t given it hell yet, but I can already tell a difference in how much my riders back rest jiggles around, it’s definitely less than it was with the power dual tune. This whole thing may be tune related, as I downloaded the canned tune when I put them on.
Anxious to ride it to see if there is much difference in the vibrations. If not, I will try to run the auto tune feature on the FP3. If that doesn’t fix it, I will put the stock one back on, or try to get the super radius’s welded again.
Old Oct 17, 2021 | 06:49 AM
golfblues's Avatar
golfblues
Talk to Cheyne at V&H....he will get you a Map that works if it's the map
Old Oct 17, 2021 | 04:10 PM
steelerdude1
Ran the old map , was a little better with the vibrations but not better enough to be happy. So I ran the auto tune for about 225 miles. It’s a little better now, at least it doesn’t feel like my feet are on one of those vibrating foot massagers. But now having bog down issue when throttling down at highway speeds.
Just not sure what I'm going to do.
I know one thing, I am regretting buying the power duals. Just too many issues that I don’t have time to mess with.
