Need Help! Issue after installing 12" KST handlebars
Have a 2021 Road Glide Limited. Installed 12"KST Spwarhead handlebars. After reassembling everything, the lights and fuel pump turn on but the infotainment system doesn't and it won't start. I checked the fuses and they seem ok. Any advice?
Check all the pins in your connectors and make sure none of them got pushed back .
The little green connector for the twist grip sensor have caused me issues in the past , even plugged it , they can be a pita . I just finished putting a set of bars ( second set ) on my bike , had that issue , ended up soldering those together and ditching the connector .
Did you use aftermarket extensions or did you solder extra wire , if you used aftermarket extensions , it's possible one or more pins pulled while you were pulling the bundle through the bars .
