2017+ Touring Model ECU all the same?
Old Nov 18, 2021 | 09:54 AM
saijintrunks's Avatar
saijintrunks
Default 2017+ Touring Model ECU all the same?
Bought bike with no ECU, now need an ECU for a 2020 CVO. Is all the ECUs for Touring models the same as far as functions? I was going to get a 2020 Roadglide ECU and get a tuner to flash it to a CVO, thanks!
Old Nov 18, 2021 | 10:02 AM
smitty901's Avatar
smitty901
I want to hear the rest of this story 2020 CVO sold with no ECU. When you purchase a new ECU it must be flashed by HD or with a copy of the factory flashed you save with a unit that allows you to. The tune is just one small part of it. Buying one off the shelf is not going to plug and play.
Old Nov 18, 2021 | 10:23 AM
saijintrunks
Bought a 2020 Street Glide CVO that was wrecked and salvaged out, thought all parts were there then tore into the bike to find the ECM missing. Now this has put a hamper on things and has slowed me down in the rebuild process. I hear that I need an ECM with RDRS as this bike is equipped with it and is going to be super hard to find another wrecked 2020 CVO that someone is parting out. Could go to HD but they don't even want to bother to help me with this bike as there are alot of hoops that they want me to jump through before they even decide to look at it.
Old Nov 18, 2021 | 12:08 PM
Ssitruc's Avatar
Ssitruc
In 2020 touring most bikes it is showing the replacement ECM being #41000724A (even on some CVO's), but on yours a CVO Street Glide replacement is showing #41000668.
In 2019 touring it is showing #41000599 for the replacement ECM(even on some CVO's), but a CVO Street Glide is showing #41000668.
On 2017 & 2018 it looks like they show #41000307 in 4 different touring bikes I checked (CVO & Non CVO).
Looks like you're gonna need a pretty specific ECM for a 2020 CVO Street Glide... and for someone to be sure it is program correctly.
Check it out yourself to be sure.
https://partsfinder.onlinemicrofiche...OIL%20ASSEMBLY
Old Nov 18, 2021 | 12:36 PM
Keithhu's Avatar
Keithhu
2021 models are equipped with a new Delphi ECM design, different from 2009-2020
Old Nov 18, 2021 | 02:16 PM
b0fh's Avatar
b0fh
aint the 2020 ECM (with RDRS) different from the previous ones?
Old Nov 18, 2021 | 03:17 PM
Keithhu's Avatar
Keithhu
Nope. Likely newer software to accomodate the additional sensors switches and displays, but same hardware if I'm not mistaken.
Old Nov 19, 2021 | 09:52 AM
pgreer's Avatar
pgreer
Yeah, this is for either a Dealer or an independent with the proper tools and know how to do the job. It's not an at home repair, at least for 99% of people. They are not plug and play parts, new ones are essentially blank units that require a flash. And with a CVO model, the correct flash must be made to match the components on the bike. And getting a used one is a no go because the VIN is coded in the ECM and must match the BCM and speedometer or you will get the VIN ERR message in the Odometer.
Does it still have a BCM or speedometer? You will need to have these parts all "married" to each other, which required the HD Digital Technician and correct flash.
Paul
Old Nov 19, 2021 | 09:55 AM
pgreer's Avatar
pgreer
Mabey a Thundermax as an ECM replacement? But there are downsides to that as an option too. And is there a BCM still on the bike?
Paul
Old Nov 19, 2021 | 10:55 AM
saijintrunks
Paul
Paul
Yeah, I checked the bike and still currently has the speedo and BCM attached to the bike. I was thinking of Thundermax as well but wanted to check other options before spending $1,100 on an ECM and send my BCM out to get recoded with new Fob $300. I have most of the other parts to put it back together but want to tackle the starting/running portion of the bike first. Would definitely make me feel better about putting the rest of the bike together.
