Anyone Using Wild 1 WO579 Bars?
Old Jan 27, 2022 | 10:26 PM
langwilliams's Avatar
langwilliams
I have them on my '14. I've had injuries to both shoulders an they fit me better to relieve the reach with the stock bars. They are larger diameter which was nice for hiding the control wiring inside but I had to trim around where the fairing met the bars.
Old Jan 28, 2022 | 10:11 PM
torchmaster's Avatar
torchmaster
I have them on my 2020 and had them on my 2017.
They are perfect for me. No more pain between the shoulders, wrist angle is much better than stock. My only gripe is they put your hands right in the center of the stock mirrors and I don't want to put mirrors on the bars. Kills the clean look of the street Glide IMO so I deal with it. I wish someone made brackets that moved the stock mirrors out just maybe a 1/2" and the same up but I haven't been able to find any.
Old Jan 28, 2022 | 11:34 PM
sixgun95's Avatar
sixgun95
Just seen these https://www.kstkustoms.com/collectio...irror-brackets
Old Jan 29, 2022 | 10:15 PM
torchmaster
Originally Posted by sixgun95
Thanks Sixgun,
I have seen these and they used to be 200+. For me they drop the mirrors too much, I don't like the look and I really only need to move them about an inch at most with my seating position.
Old Jan 29, 2022 | 10:41 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Compared to the stock bars, do the 579's sit taller? I understand they are wider with more pullback.
Did you have to trim any of the plastic in the fairing to get them to fit properly?
They do sit a little taller (1" at most). No modifications needed on 2017
Old Jan 30, 2022 | 02:04 PM
peddler's Avatar
peddler
I know someone mentioned earlier they had to modify a Rushmore fairing to accommodate the WO579 bars. I'll check the next time I see my bike. I have no recollection of modifying my fairing for the WO bars.
Old Jan 31, 2022 | 03:21 PM
StrtKing's Avatar
StrtKing
Do you need new cables for the 579’s?
Old Jan 31, 2022 | 03:51 PM
sixgun95's Avatar
sixgun95
No. Just extensions of the grip switches and heated hand grips.
Old Jan 31, 2022 | 07:00 PM
hattitude's Avatar
hattitude
I DIDN'T Have to modify my 2016 Rushmore Fairing...
But if you don't trim the left side grip portion of the bar (it's in the insatll directions) you'll have a gap between the left side switch-pak, and the fat portion of the bar... about 1/4"... I misread the instructions and didn't trim mine..
I posted a pic of the gap, in my post above... Post #2...
Old Jan 31, 2022 | 07:29 PM
peddler's Avatar
peddler
That was my experience. I did trim the left side and it eliminates the potential gap between the switch-pak and the point where the bars transition to 1 1/4" diameter.
