Stupid question about shocks
Old Feb 9, 2022 | 08:13 PM
Ghetto blaster's Avatar
Ghetto blaster
As far as the front a complete upgrade would be the "easiest" way, or; you could try differing oil weights, upgrading the springs, add valving, etc., however each upgrade would require tearing into the bike = less riding, so save that **** for the winter.
Old Feb 9, 2022 | 09:18 PM
Max Headflow's Avatar
Max Headflow
I could be wrong but I think he's talking about rear shocks.
Old Feb 9, 2022 | 09:25 PM
jimsuver's Avatar
jimsuver
The current swing arm is basically the same since 2002 except that they made it wider in 2009. 2001 and earlier were weaker. Hd has used the same swingarm since 2009 no mater if the shock pair were same or asymmetric. Bearings and pivot shaft were the same except in about 2011 they changed the pivot shaft to a cheaper to manufacture, reduce part count and easier assemble.
This is great news as I am using the current shocks on my 2007. They work much better than the 100,000 mile air shocks did.
Old Feb 9, 2022 | 09:30 PM
mseawell1022's Avatar
mseawell1022
My original question was about the rear shocks. But I did, later I the thread, ask about the need to upgrade the fronts as well.
Old Feb 9, 2022 | 09:57 PM
Max Headflow
I missed that.
Old Feb 11, 2022 | 11:05 PM
Traildale's Avatar
Traildale
This is an over simplification -
Rear shock upgrade is 80% comfort and 20% improved handling.
Front shock upgrade is 20% comfort and 80% improved handling and reduced braking dive.
13” aftermarket rear shocks are the biggest single improvement you can make to a bagger, especially if you have the junk stock air shocks. As you found out, the air leaks out, air pressure changes with the temperature, and the 2 inches of travel is pathetic.
Old Feb 12, 2022 | 05:50 AM
StreetGlide2021's Avatar
StreetGlide2021
On my 07 FLHX, I had set my shocks at 14 psi, higher with a passenger, and upgraded to a Mustang seat with a backrest for lower spine support. My rear shocks never leaked air, for which I am thankful.
For my 21 FLHXS, I am interested in new rear shocks and haven't decided which brand/review is right for me.
justin_ryan
Jun 7, 2015 09:45 PM
13bob
Sep 14, 2014 07:29 AM
dirtdobber
Aug 5, 2014 07:41 AM
Midgard
Jan 23, 2013 05:44 PM
dreamer65
Dec 31, 2010 03:21 PM
