2011 ultra question
Done the same maintenance as you and I've never had any problems.
I did just replace the suspension with Ohlins shocks on the rear and Progressive Monotube Fork Cartridges up front. So no need to replace the fork oil or seals in the forks now.
My lifters started getting loud around 32,000 miles but I just keep the oil changed regularly and they keep quite.
I always check the wheel bearing with every tire change and check my drive belt several time a year.
Other than that I would say just making sure everything is tight and lubed and you should be fine.
You have the hydraulic cam tensioners with o-ring chains, so you are good there...
You have the updated self-adjusting primary chain tensioner, so you're good there...
Your bike was built before 10/1/2011, so you missed the bad batch of regulators, so you are good there...
You have the upgraded '09+ frame which includes better engine mounts (early twin cam baggers had some issues), and less chance of rear end "wobble" over earlier twin cams, so you're good there...
Your compensator isn't the best version of that era, but it's not as prone to failure as earlier versions, and doesn't need attention unless making noise or giving you problems...
You are the second year to get the crappy "C" lifters, but unless they start making noise, no reason to go into the cam chest... unless of course you want a new cam, then I'd change the lifters and inner cam bearings "while you're in there"...
When Harley went to the 25mm wheel bearings (2008 or 2009+), there were some that had issues... Whether it was a bad batch, or something about the bearing make/size is debatable, but on all my bikes I've gotten into the habit of checking wheel bearings at all tire changes, and if there are any signs of issues...
IMHO... you are at a pretty good place with that year bike to ride it, perform required maintenance, and just address any issues that develop, which will happen to all makes, models, years.....
Enjoy...!
