Need help regarding fairing removal
Old Mar 6, 2022 | 05:50 PM
Scojo64's Avatar
Scojo64
3rd Gear
Default Need help regarding fairing removal
Hello, I have a 1998 Harley Davidson Standard, I took the inner and outer fairing off to change the stock handle bars to a pair of LA choppers bars. while re-installing the inner fairing I notice that the inner support left side upper mount location was completely broken off and missing, (honestly not sure if it was like that before I took it apart and never noticed) so my questions are A) can the inner and outer fairing be put back together with out this support location and if not B) has anyone ever completely removed the fairings and gauges and just ran the front end like a chopper? I'm interested in constructive advice on how I can get past this point.
Thanks for any and all input,
Scojo64
Old Mar 6, 2022 | 07:33 PM
05flhtbob's Avatar
05flhtbob
Pics would help but it sounds like its the one that is common to break there may be a updated part now..
Old Mar 6, 2022 | 07:54 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
That part breaks all the time, upgraded parts are available in the aftermarket on Amazon, JP, Drag, etc.
Replace it before putting the bike back together.... replace both.
Old Mar 8, 2022 | 05:41 PM
Scojo64's Avatar
Scojo64
3rd Gear
Thanks for the responses, I apologize for not providing a photo, here is a photo to help confirm what I have broken is what you guys are referring to,
This is a photo of the right hand side of the inner fairing with the upper mounting point still intact
This is a photo of the eft hand side of the inner fairing with the upper mounting point broken off and missing.
Old Mar 8, 2022 | 05:52 PM
FreddyP's Avatar
FreddyP
Hi @Scojo64 . Had one mount on the inner fairing side crack and the other side completely broke out like yours. I was lucky enough to find it with all the parts still there. Here's a thread I created with pictures and a write up for how I fixed mine. Did not want to go through the hassle of removing and replacing the entire inner panel. Also had to use an angle bracket and fabricate a repair for broken tab on one mount.
https://www.hdforums.com/forum/touri...ing-posts.html
Hope this helps!
Old Mar 8, 2022 | 06:09 PM
Musician's Avatar
Musician
I have an '08 FLHT, and naturally, that bracket broke first year I had the bike. Those polymer brackets weren't around then, not that I knew of. Rather than spend extra to replace it with another of the same quality, I used a couple cheap angle brackets that cost about a buck and a half for 4 of them. Drilled the appropriate holes in the existing bracket, bolted them together with the 1/4-20 nuts and bolts .Dremeled off the excess. Into it for under 5 dollars total. All these years, and 140,000 miles later, still solid, and haven't had any problem with them at all. Might not be all that pretty, but who's gonna see them?
scot210
Jun 13, 2011 11:23 PM
tincup64
Mar 28, 2011 06:21 AM
jimsflh
Feb 9, 2010 03:46 PM
blown alcohol
Feb 2, 2010 10:52 PM
Firecap501
Aug 29, 2008 07:03 AM
