Clucth Problems
Old Mar 20, 2022 | 11:01 AM
FLHXIGlide's Avatar
FLHXIGlide
Default Clucth Problems
Hi, new to this forum and hoping some one can give some advice. Working on my friends 1995 Road King and having clutch issues. After adjusting the clutch cold its hard to get into first (excessive grinding), As the bike gets hot the grinding gets somewhat better but not right (still grinding). I have tried backing off the adjusting push rod @ 1/2" 3/4" and 1" full turn and it still grinds bad when cold. At 1" it seems to lessen the grind when hot, but still not right. The clutch pack was replaced about a year ago and the problem still existed. The clutches removed were worn excessively some friction material worn off completely with blue heat related steels and clutches. This bike was bought new and the owner says it has been doing this for most of its life. It now has 95k on it. It seems that the clutch is not releasing completely to put into gear, shifts great up and down while moving but won't go into first while sitting still. If any one has any ideas on what to look at that can causing this problem your help is much appreciated. Thanks
Tom
Old Mar 20, 2022 | 11:18 AM
702's Avatar
702
Are you guys putting slack in the cable first?
Old Mar 20, 2022 | 11:23 AM
FLHXIGlide's Avatar
FLHXIGlide
Yes Absolutely
Old Mar 20, 2022 | 11:39 AM
Stiggy's Avatar
Stiggy
Throw out bearing (on the clutch actuation side,) failing?
Old Mar 20, 2022 | 11:44 AM
WVHARLEEMANN's Avatar
WVHARLEEMANN
Hello and welcome to the H D Forums from West Virginia. Glad you have joined us all here.
Old Mar 20, 2022 | 12:47 PM
FLHXIGlide's Avatar
FLHXIGlide
Default Clutch Problems
Stiggy:
Are you talking the little bearing on the the clutch rod release end or the big bearing on the the clutch hub? Thanks for your reply!
Tom
Old Mar 20, 2022 | 12:52 PM
FLHXIGlide's Avatar
FLHXIGlide
WVHARLEEMANN:
Thanks for the warm welcome!
FLHXIGluide
Old Mar 20, 2022 | 02:42 PM
Stiggy's Avatar
Stiggy
Originally Posted by FLHXIGlide
Stiggy:
Tom
The 'little' bearing (accessed from the right side of the motorcycle.) Hard to find neutral and hard to shift are some of the symptoms.
Old Mar 20, 2022 | 04:42 PM
FLHXIGlide's Avatar
FLHXIGlide
Stiggy:
Thanks i'll check that out.
Tom
Old Mar 20, 2022 | 08:00 PM
Hawg Runner's Avatar
Hawg Runner
When they did the clutch job, maybe one plate too many?
