Rusty disc
Old Apr 13, 2022 | 03:35 PM
BRKLYN1955's Avatar
BRKLYN1955
Default Rusty disc
Hi guys, is there a chemical to remove this ruck, or try Coca Cola on it?
Old Apr 13, 2022 | 03:55 PM
Hawg Runner's Avatar
Hawg Runner
Personally, I would remove the wheel and use a wire brush, some fine emery cloth and paint them.
Old Apr 13, 2022 | 04:55 PM
memphisharley's Avatar
memphisharley
half a Saturday job
Old Apr 13, 2022 | 05:10 PM
im's Avatar
im
Keep in mind that bearings are right at that location so use caution.
You also have 2 discs but 4 sides.
What are the conditions of bearings?
Are the calipers OK.
It would probably be best to jack the bike UP and remove the wheel and inspect calipers & bearings.
If bike is in San Juan then it looks like it was maintained out doors.
With wheel OFF I would try some wet sanding paper...maybe 2000 grit.
The sliders could use some time too.
What is the date code on those tires?
Old Apr 13, 2022 | 06:46 PM
RKZen's Avatar
RKZen
I've always had great results with Flitz polish here. You could use a polishing disc or #0000 steel wool to make it easier.
Old Apr 14, 2022 | 01:35 PM
WVHARLEEMANN's Avatar
WVHARLEEMANN
^^^^^^ +1 On the Flitz. Great product !!
Old Apr 14, 2022 | 02:37 PM
GOGOBECK's Avatar
GOGOBECK
If you try 1000 grit or #0000 steel wool, you will be worn out before making a dent.
Take the rotors off, work on a flat surface, place a towel underneath. Start with 600 grit and a random orbital sander, go to 320 grit. You can stop there or keep getting finer, finish on a buffing wheel if you want them to really shine.
I stop at 320 and polish on a buffing wheel… I prefer the look over fully chrome like polished.
Old Apr 14, 2022 | 02:40 PM
GOGOBECK's Avatar
GOGOBECK
320 grit and light polishing, both the lower legs and the rotors.
Old Apr 14, 2022 | 04:32 PM
BRKLYN1955's Avatar
BRKLYN1955
Bought it in Edwin Twp N.J. and shipped outta Philadelphia. A bike like that here is just under 10k.
Old Apr 14, 2022 | 04:35 PM
BRKLYN1955's Avatar
BRKLYN1955
Thank you all, looking to perhaps light sand and paint a matching color.
Harrygreb
Welcome Area Only
28
Nov 10, 2019 05:52 PM
tennispro1
Jun 7, 2013 10:34 PM
galeb
Welcome Area Only
Dec 16, 2012 03:49 PM
Big Chris
Jul 13, 2010 06:09 AM
