Puzzling
Old Apr 16, 2022 | 06:56 PM
jake24lt's Avatar
jake24lt
Originally Posted by Gary Wilson
I would carry a can of starting fluid or such. Then when it quits it should try to run on the canned fuel "if" it is a fuel issue. Just get a can with the small tube on sprayer and spray into filter.
Then if it doesn't try to start or run on the fuel you can rule out the fuel issue.
I would bet on the coil going out. Have seen a few do that as in stop working once it gets hot.
Could also carry a spark plug that you have tested and shows good spark with your bike turning over.
Ride Safe✌🏼
ether in a hot engine is asking for trouble.. ..
Old May 4, 2022 | 08:15 PM
skyrhon's Avatar
skyrhon
Stage IV
[QUOTE=RIPSAW;20562494]It would have been helpful if you had typed in the header...
2011 Limited occasionally cuts off and won't restart. Help needed .
It the text, it would be good to know when and how you get it to restart.
​​​​​​Thanks everyone for your input. It turns out it was the PowerCommander.
Old May 13, 2022 | 05:48 PM
Jackie Paper's Avatar
Jackie Paper
Too cool.
My48sporty
Aug 8, 2021 04:58 AM
TrippAAA
Aug 30, 2020 09:47 PM
Sk24
Apr 10, 2020 08:47 AM
Sk24
General Topics/Tech Tips
Apr 10, 2020 06:48 AM
Dhock83
Apr 14, 2015 01:35 PM
