Tire valve not taking pressure
Old Apr 16, 2022 | 09:14 AM
MedicineBow's Avatar
MedicineBow
Originally Posted by Keithhu
Are the valve cores the same size as on a normal car, can I just go to the auto parts store? I like the quick removal idea.
Yes. Cars and HVAC typically use Schrader valves.
Old Apr 16, 2022 | 09:19 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by MedicineBow
As others have stated, try a valve core removal tool. You can replace it quickly and then just pump it up. Decades ago I did HVAC work and there is a tool that allows you to change a Schrader core under pressure.
https://www.amazon.com/Schrader-Remo...92953912&psc=1
........, I have two of those I use for evacuating HVAC systems. They allow me to remove the valve core without losing any pressure or allowing any air into the system if I`m evacuating a system. They work really well....
Old Apr 16, 2022 | 09:42 AM
diablos's Avatar
diablos
I couldn't get the core that came with my dyna beads to work, but the original did. Similar issue here?
Old Apr 16, 2022 | 10:03 AM
brakeless's Avatar
brakeless
I would lean towards the chuck being bad. I asked my teenage grandson to air up my GPW's tires and he tried for a long time and said the tire has a hole in it because he could hear air coming out as he was putting it in. After he left, I tried it and it worked fine! Apparently he wasn't pushing the air chuck down hard enough to depress the center pin. Does your air chuck have the trigger type with the gauge? Does air come out when you press the handle, or trigger? If not, squeeze the handle and press the center pin to see if air comes out. I have several types and one of them is just a plain chuck that plugs into my air line. No messing around there and it's easy to release too much pressure from the tire with a gauge/checker.
Old Apr 16, 2022 | 10:46 AM
Keithhu's Avatar
Keithhu
Yep, that was it. Replaced chuck, all good, thanks!
Old Apr 16, 2022 | 05:10 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Old Apr 16, 2022 | 09:26 PM
Sam2010's Avatar
Sam2010
Compressor air pressure too high. Try to lower pressure at Compressor. It's happen to me before.
Old Apr 17, 2022 | 12:11 AM
WVHARLEEMANN's Avatar
WVHARLEEMANN
👍👍Glad ya figured it out.
Old Apr 21, 2022 | 12:10 PM
hattitude's Avatar
hattitude
For future reference, I recently bought one of these based on several recommendations...
JACO FlowPro Digital Tire Inflator with Pressure Gauge- 200psi
https://jacosuperiorproducts.com/pro...-gauge-200-psi
This is the best air "chuck" I've ever used on my bikes... and cars... and trucks... and trailers... and RV... Well, you get the idea..
Old Apr 21, 2022 | 01:34 PM
brakeless's Avatar
brakeless
Pros and cons I guess. The locking type chucks can be good in certain applications. For example on the big truck tires that take forever to fill. On the kids bicycle tires I found if you pull the tube nipple up and clamp a small pair of needle nosed vice grips on it to hold it in place then you can clamp the chuck on and have one hand for the fill lever and one hand to feel the tire or hold the wheel if it's free spinning. However, I have yet to find one that fits the wire spoked rims on my bike where I need to use a short angled chuck. My tire gauge has a loose fitting chuck so I can switch it up to whatever chuck I need. But, I will say I've never tried one with the long straight locking chuck.
