On my new to me '04 Road King Classic I find the reach to the grips a little longer than I like. I have been searching and it appears this is not an uncommon issue.
One of the most common solutions is a set of Heritage bars. The only ones I can find from Harley say they are for '08 and later models but I have seen many posts and even a review for them on the Harley site from guys with earlier bikes like mine using them.
I bought an ‘02 that had heritage ST bars, I swapped ‘em out for HD’s “tall boy” bars… a bit wider and not quite as tall as the Heritage bars. Fit me perfect.
They don’t come with the holes for internal wiring, easy enough to drill though.
Don't over think this. Bars are bars. If they mate fine at the clamp they will work. The bike doesn't know the difference. Drill and de bur holes for wiring and enjoy it
I'd get the fatter bars, especially if you want internal wiring. And if you plan to do heated grips. More room for the wiring.
If you like the Heritage-style bars, give KST Kustoms a call. They don't normally sell them but they can make the Heritage-style bars in 1 1/4" for you. That's what I have on my '13 King.
Thanks. I couldn't reckon why they would not work. I need to do some more research as I am looking for bars with a couple more inches of pullback than the stock bars but also don't need new cables. I'm not looking to rout them internally and would like the ease and cost benefit of using all the original cables.
Hell yea, if the stocl wires are in goos shape just run what ya brung. Id start lookin st ways to run the wires internally. It's not hard but can be frustrating. There are severak ways. If i remember correctly i used a small nut on weedeater string from bottom to top, taped the wires to the string, gave it a shot or 2 of whatever lube you have and get to pulling. Dont use astroglide tho, it's too sticky lol
The 02 RK in my sig has 16" internal wired apes. I'm 5"11 on a good day and I love them. but everyone is different. the best advice I can give you is to try to find a similar bike with bars you think you want and ask if you can sit on it. most people will understand and let you. otherwise, your just guessing and guessing gets expensive.
I think the type of riding you do determines where you want the bars… if you’re carving up the twisties, you want wider bars and low enough to get on top of the grips, leaning your upper body forward vs. laying back is a benefit if you like hard cornering.
If you’re a highway cruiser, I think taller and a bit narrower bring more comfort.
I like the tall boy bars, because, I can layback a bit and relax at times and I can straighten up and lean into the bars when I ride more aggressively. I’m 6’1”
