08 fuel gauge replacement issues
Old May 15, 2022 | 08:13 PM
cprhed's Avatar
cprhed
Default 08 fuel gauge replacement issues
Had the needle dancing crap. Replaced the parts in the tank first and filters. Still dancing.
ordered a new gauge and when I plug the new one in it doesn't work.
Is there some magic to marry the gauge to the bike? It just stays dead on empty.
I plugged the old one back in and it still dances.
I'm thinking I got a bad gauge from the dealer.
Old May 16, 2022 | 09:28 AM
cprhed's Avatar
cprhed
Reply for clarification
My main question is, The most likely for this behavior would be that the new gauge is bad correct?
Old May 16, 2022 | 09:45 AM
hattitude's Avatar
hattitude
Check the pins in the gauge connector plug....
On a softail I had, after removing the gauge, I had all sorts of issues with improper or intermittent gauge readings. I know it's a different gauge set up, but I believe it has a similar connector plug into the harness, if I remember correctly. One of the gauge connector plug pins got bent as I was plugging in the gauge... The gauge didn't work well for awhile...
I finally inspected that plug-in connector, found the bent pin, re-pinned the connector, and all is well...
Just a thought about something to check...
cprhed's Avatar
cprhed
Well if I was smart enough to read I might have saved myself some grief.
Original part number 75111-08
Part number on box for new gauge 75111-08
sticker on new gauge that reads empty all the time 75111-96C
sticker on new gauge says 80-14 Ohm
Sticker on OEM gauge says 252-40 Ohm
sonofa
cowboybob56
Feb 2, 2018 10:05 AM
Srowe
Jun 1, 2012 05:57 PM
soold
May 11, 2012 02:38 PM
airbisket91
Exhaust System Topics
Sep 14, 2009 03:37 PM
hall1836
May 25, 2009 10:52 PM
