Electrical problem
Old May 27, 2022 | 07:11 PM
Yamabushi's Avatar
Yamabushi
Default Electrical problem
I have a 2021 FLHRXS. Today I swapped handlebars I was careful to turn the ignition on then remove the master fuse. I marked the three wiring bundles from the handlebars before disconnecting them from behind the headlight. Everything seemed to go fine and I reconnected everything but when I reconnected the master fuse and turned on the ignition I get the whine I expected when I flip the run switch, but the start switch doesn’t do anything. Also no central display. And I can’t change the headlight from low to high beams. Probably other stuff is missing too. Assuming that I reconnected all the wires correctly in the nacelle, any suggestions on what could be wrong? None of the fuses are blown so I don’t think it’s a short.
thanks in advance.
Y
Old May 27, 2022 | 07:36 PM
Navy Mustang's Avatar
Navy Mustang
Only answer is you must have incorrectly connected some of the wiring. If it were me, I would remove the bars and start over. You're looking at about 4 hours.
Old May 27, 2022 | 07:55 PM
Yamabushi's Avatar
Yamabushi
thanks, but I’m thinking that I might have pinched or disconnected a wire in one of the control modules. I’m planning on removing them tomorrow and checking for anything disconnected or pinched.
Old May 27, 2022 | 08:00 PM
rideonva's Avatar
rideonva
On my RG it was impossible to connect harnesses wrong, I suspect yours would be same way ? Anyway looks like both sides have issues so I’d agree with previous poster: disconnect everything, try to connect one side at a time and see if you get response from one side.
Old May 27, 2022 | 08:01 PM
MyFavRk's Avatar
MyFavRk
While your at it , look at all the pins in the connectors and make sure they didn't push out . The little green connector on the TGS has been an issue for nearly everyone who has done their own bars , most just solder the wires in line and ditch it .
I've done a dozen or more bars and always got rid of that connector , but it does sound like your having more issues with other connectors as well .
Old May 27, 2022 | 08:04 PM
WP50's Avatar
WP50
Are the bars wired internally ?
Old May 27, 2022 | 08:16 PM
Yamabushi's Avatar
Yamabushi
the wires are run inside the bars but they did not come pre-wired
Old May 28, 2022 | 06:41 AM
Highclasshobo's Avatar
Highclasshobo
I'm assuming your HD has the Deutsch connectors as all of the older models. If so when I did my bars I had a similar problem and when I disassembled I discovered that a few Deutsch pins were not seated all the way. They looked like tey were but on closer inspection they were about 1/10 of an inch shorter than the rest of the connectors. It's an easy check anyway something to rule out
Old May 28, 2022 | 08:35 AM
LoneBone's Avatar
LoneBone
Most likely you pinched one or more wires, in the switch housing. That's where I would look first. Rats nest of wires in a little box, so you wouldn't be the first one that's damaged wires there. Have to be really careful. Check that then go from there.
Old Jun 4, 2022 | 09:36 AM
Yamabushi's Avatar
Yamabushi
That is exactly what happened. I pinched one on each side. Instead of trying to repair them I opted to buy a new set of wires. One less thing to worry about. Installing them tomorrow. Thanks for all the comments and advice!
