Electrical problem
Old Jun 11, 2022 | 07:13 AM
Yamabushi's Avatar
Yamabushi
Originally Posted by Yamabushi
That is exactly what happened. I pinched one on each side. Instead of trying to repair them I opted to buy a new set of wires. One less thing to worry about. Installing them tomorrow. Thanks for all the comments and advice!
My problems continue. After replacing the wires I checked the connections and the right switch module seemed dead. When I reinstalled the master fuse none of the dash lights come on. I rechecked all the wires and it seems like everything is right, but no dash lights (odometer and all the other indicator lights). After disconnecting the two connectors from the module the indicator lights come on, just like I would expect before starting the engine. Plug the smaller connector in and nothing changes. Plug the bigger one in a the lights go out.
I drove an hour to a HD dealer and bought new RH wires and a new RH switch module for $300. I connected the new wires to the module and connected the other end of the wires to the connectors in the nacelle and got the same results.
So it seems that the wires are not the problem and the switch module is not the problem. Any ideas what could be going on?
Like I said at the beginning all I was doing was swapping handlebars.
thanks!
Old Jun 11, 2022 | 09:17 AM
predatornut's Avatar
predatornut
When I did my bars I got the right and left side connections mixed up. They connected but nothing worked right. Just something to check.
Old Jun 11, 2022 | 09:40 AM
Yamabushi's Avatar
Yamabushi
thanks. I marked the wires before disconnecting them but I’ll double-check
Old Jun 12, 2022 | 02:42 PM
Yamabushi's Avatar
Yamabushi
Finally got it figured out. I thought the LH, which is installed first, was good until I noticed that the high beams weren’t coming on. This morning I took it off and reinstalled it, being extra careful to keep the wires free of pinching. After that everything was working. I kept checking as I installed everything else and when I put the last screw in the headlight ring everything was good.
all done and I definitely won’t be touching the damn handlebars anymore!
thanks for all of the comments
Old Jun 12, 2022 | 02:49 PM
WP50's Avatar
WP50
It's called Experience
Ya got a good dose of it seems LOL
Glad ya got it fixed
WP
lylew6203
Jan 6, 2020 12:08 PM
WallyWhite
Electrical/Lighting/Alarm
Nov 2, 2017 02:30 PM
Crossbones
Jun 24, 2012 07:31 PM
popstheoldman
Jan 1, 2009 08:32 AM
joechief
May 30, 2006 08:08 PM
