2015 Road King primary noise
Old Jun 15, 2022 | 11:42 AM
jp0469's Avatar
jp0469
Default 2015 Road King primary noise
Recently noticed a lot of additional noise coming from my primary; kind of a chattering at certain RPMs. Since I had also noticed the signature compensator clunk when turning off the bike, I was hoping the compensator was the sole cause. I swapped out the stock compensator for a Darkhorse Man-O-War and the clunk is gone but the chatter is not. Chain and tensioner all look fine so I'm now in the middle of replacing the inner primary bearing and the clutch bearing. Since I'm this far into it, what else should I inspect or replace while I'm in there? There are no signs of any oil leakage anywhere behind the primary. Should I replace the shifter shaft seal or just leave it alone since there is no sign of a problem? Bike has 35k miles BTW.
Old Jun 15, 2022 | 02:12 PM
ratpick's Avatar
ratpick
Subscribed, I'm curious how this plays out.
Other than lack of clunk, did you notice any other differences w/Darkhorse sprocket?
Old Jun 15, 2022 | 08:34 PM
jp0469's Avatar
jp0469
No real significant difference in feel or performance with the Darkhorse. About the only thing I possibly noticed is that when slowing down while using engine braking, there is less bucking as you approach lower RPMs.
LoneRiderFLH
Aug 4, 2021 07:35 AM
Alias69
Jul 17, 2015 11:31 AM
jpooch00
EVO
Mar 19, 2012 05:46 AM
drfalken
May 25, 2009 09:52 PM
Road King Kid
16
Jan 15, 2007 04:44 PM
