bypass cruise limiter
Old Jun 18, 2022 | 11:01 AM
dickey's Avatar
dickey
Why not just slow down a tad?
Old Jun 19, 2022 | 06:58 AM
Ultra103's Avatar
Ultra103
I wonder what years they did that? I ride 85 for quite a distance when visiting family in the next state. That limiter would be annoying for sure.
Old Jun 19, 2022 | 09:13 AM
Cobra1's Avatar
Cobra1
Is this the same as newer model came out? I have set my cruise at 80 but I don’t believe much higher as I rarely ride interstates. Now I may just have to go for a ride and see. lol
Old Jun 19, 2022 | 09:28 AM
Vernal's Avatar
Vernal
I think mine will set just above 90.
This is from a 2016 manual:
Old Jun 19, 2022 | 09:45 AM
rigidthumper's Avatar
rigidthumper
TTS, PV or Direct Link tuners all have the ability to correct the speedo, which should fix the issue. HD speedos of that era were known to be 3-6% optimistic, and any of the tuners mentioned can correct that. On my 08 , I could set my cruise @ 85, and bump the + 2-5 MPH above that, and it held fine, unless I hit a bump big enough to unload the rear tire. I used a TTS on that bike.
Old Jun 19, 2022 | 11:16 AM
hattitude's Avatar
hattitude
Thanks for that info.....
I was just cruising a section of I-15 yesterday on my '16 Bagger, with my cruise set at 85mph per the speedo (GPS was showing 83 MPH)... worked flawlessly going up and down some hills in the area I was cruising in....
It wasn't until I got off the freeway at my exit, that I realized I was using the cruise control @ 85mph, and thought of this thread... I would have played a round a little to see my cruise control limitations....
Old Jun 19, 2022 | 05:47 PM
Sc0-'s Avatar
Sc0-
'09 has 85mph cruise control limiter, even with a stage 4 tune or whatever from FuelMoto. Learned to live with it.
Old Jun 20, 2022 | 12:11 PM
mezlo's Avatar
mezlo
6th Gear
Thanks. I have a TTS MasterTune blue interface for my 2005 FLHRCI. I will send it in and get it upgraded to dual bike and see how it works.
Old Sep 13, 2022 | 09:53 AM
mezlo's Avatar
mezlo
6th Gear
FYI, using TTS MasterTune BT with my blue analog tuner, I changed the speedometer value from 2240 to 2140. Not only is the speedo almost spot on now, but I've hit 90 while accelerating with cruise set and it hasn't disengaged. Problem solved.
Old Sep 13, 2022 | 11:08 AM
Puglia10's Avatar
Puglia10
A tuner can definitely shut that limit off. I'm not sure which brand, or just bring it to a dyno shop and tell them you want it shut off.
RET_SCPO
Jul 29, 2022 12:53 PM
ArizonaKid
Oct 10, 2021 08:23 AM
a99miata
Jul 9, 2012 06:56 PM
cruiscont-fxdf
Jul 28, 2010 10:38 PM
KY23
National Events
30
Jun 28, 2009 08:07 PM
