fuel filters
I do all my maintenance. Only thing I have put a fuel filter on in years is my Jeep. It has 320,000 on it.
Now if you fill up your bike, boat or power tools from a rusty 5 gallon can sitting in the shed, that's different.
Also, that idle check applies to modern fuel injection. Not older 1990es system with stage pressure FI system and of course carburetors.
If you travel long distances, or it gives you warm fuzzy fillings, do it. It's not going to leave you setting but if you start to loose your idle and need to crack the throttle for idle, on a trip, it could get dangerous.
PS.. Make your next new post over in the new member area.. Just in case .
Welcome from North Beach, FL., USA!
Just in case you have not done this and only as a suggestion.
Add a Signature Line in your USER set up for your bike year, model, and all the letters that Harley recognizes it with so others see at the bottom of all your post. This enables others to know your exact model if you ever ask a question.
And an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post.
Your all set.... Enjoy the ride! ______________
