LA Chopper Bars
Old Aug 14, 2022 | 10:54 AM
flylgw1's Avatar
flylgw1
6th Gear
Default LA Chopper Bars
Would someone know if you Can you use the stock wires and cables on the 12” LA Chopper Twin Peaks Bars on the 2014 Ultra Classic! Thanks…..
Old Aug 14, 2022 | 03:33 PM
johndoe297's Avatar
johndoe297
This post is a few down from your's from the other day. Should have the answer you need.
https://www.hdforums.com/forum/touri...swap-help.html
Old Aug 14, 2022 | 07:53 PM
Fddk's Avatar
Fddk
I put the same bars on my 2017 Ultra Limited. No need for extensions, easy install. Lots of videos on you tube to help you out.
Old Aug 15, 2022 | 09:45 AM
flylgw1's Avatar
flylgw1
6th Gear
Thanks for Info fddk! Appreciate it….
Old Aug 15, 2022 | 09:49 PM
Fddk's Avatar
Fddk
No problem. Factory 47 has a great video on how to do it, it’s the one I mostly used. They do 14 inch bars that are even wider than the ones you’re putting on. I found the bars to be a great improvement over stock, well worth the effort.
Old Aug 15, 2022 | 10:01 PM
FLshovelhead's Avatar
FLshovelhead
I was able to get 14” bars on my 2017 FLHTK without swapping cables.
https://www.hdforums.com/forum/touri...and-hoses.html
Old Aug 17, 2022 | 09:47 AM
flylgw1's Avatar
flylgw1
6th Gear
Thanks Shovelhead!
JlovesK
Mar 9, 2022 12:54 PM
808odie
Mar 3, 2020 11:02 AM
Travis Davis
2014-2024 Touring Models
Apr 17, 2014 07:05 PM
chopperwallace
Jul 19, 2013 03:33 PM
LAC187
Vendor For Sale Classifieds
Jan 9, 2012 05:43 PM
