If a passing light quits will your headlight only work on bright? I'm having this issue. I haven't had time to check fuses or relay yet.
Tks for all comments
Dean.
Reason: Forgot to mention something
You mention passing light, if you are talking about the side passing lights they only work on low beams by default. When you switch to high beam they shut off. There is a dealer mod that can make the passing lights work w high beams but it doesnt from the factory.
if any of the passing lights burn out the main headlight will continue to operate. They are on separate circuits.
