FLH engine interchange?
Old Aug 20, 2022 | 10:06 AM
mn.roadking's Avatar
mn.roadking
Default FLH engine interchange?
What year motors will be a direct bolt in for a 2005 Road King?
Old Aug 20, 2022 | 10:09 AM
Rounders's Avatar
Rounders
Maybe 2003 or 2004- 2006. What year did they go 3 wire stator and bigger stator on all touring bikes?
2002 was last year timken
Old Aug 20, 2022 | 12:14 PM
Keithhu's Avatar
Keithhu
I would think any touring TC88, so what - 1995-2006? I could be wrong, ask my wife.
Old Aug 20, 2022 | 01:00 PM
buell95's Avatar
buell95
Im not 100% sure but i think the early TC had a cam position sensor
Old Aug 20, 2022 | 03:55 PM
Rounders's Avatar
Rounders
Another guy here tried swapping years,maybe from dyna, there are things you have to know from primary allignment and rotor.
They have different stators when they went to 3 wire. So early one won't match his volt reg
In 2001 ulrras had 45 amp charging HRs 38. They had shim under comp.
2002 last year of timken bearing that may have effect on mating things up.
2001 still had cam sensor on fi. Carbed did not. After market ignition modules for carbs can get rid of cam sensor
99 2000 had the bad cam bearing.
Old Aug 22, 2022 | 07:13 PM
hattitude's Avatar
hattitude
The 1999-2000 TC88 engines had the cam position sensor AND the CKP.....
If you swap out a '99-'00 carbed twin cam's ICM with one from Daytona Twin Tec, you don't need the cam position sensor and can remove it...
I'm not sure how the MM EFI uses the cam position sensor.... but the 2001 Touring MM EFI bikes still had the cam position sensor and CKP.
All other models, including the Delphi EFI softails in 2001, didn't have the cam position sensor.
tinkering
Shovelhead
Dec 13, 2021 07:24 PM
IronAss
Jun 17, 2019 06:20 AM
Deni2010
Jul 12, 2010 08:21 AM
Ironbarr
Jun 22, 2009 08:02 AM
btefft
Apr 1, 2007 04:23 PM
