2014 roadking lighting problem
Old Sep 7, 2022 | 01:21 PM
Dalbert's Avatar
Dalbert
Stage I
Default 2014 roadking lighting problem
Hi my name is Joe I'm new to the form I have a 2014 Harley Davidson Road King flhr all the lighting works the only thing that doesn't work is the two rear running lights the hazards work everything else works except the left turn indicator on the gas tank the LED that and the two rear running lights do not work can someone help me
Old Sep 7, 2022 | 08:36 PM
FLHRinFL's Avatar
FLHRinFL
In stock form, the rears are are turn signal only. As for the dash light remove the seat and the tank console. My '95 has replaceable lamps, not sure about your '14. A Factory Service Manual is a must if you're going to do your own work.
Old Sep 9, 2022 | 01:00 AM
cowboydoc's Avatar
cowboydoc
On a stock Road King, only the center tail light is on as a running light. The two smaller lights are amber and turn signal only. Like many others, I have modified mine to be running lights as well. Legally (in the US at least) if they are running lights they need to be red, not amber. If the lenses are amber then they are turn only. Mine are Custom Dynamics, red with smoke lenses.
The indicator lights on the dash are one unit on the 2014 and newer bikes. One of my signal indicators went out and was replaced under warranty, but it is an easy swap to do it yourself.
Marcus94501
Electrical/Lighting/Alarm
Apr 12, 2021 10:47 PM
dyna bob 583
Jun 15, 2016 12:25 AM
mtnroadking
Mar 17, 2013 03:19 PM
Stevieskull
Apr 4, 2012 02:12 PM
karjar
Jul 6, 2010 12:30 PM
