LED signals Hyper-Flash dash only
Old Oct 31, 2022 | 10:41 AM
shore's Avatar
shore
Default LED signals Hyper-Flash dash only
'22 SGS. Amazon LED signals front and rear. The reason behind these are they don't have the light flopping around inside the lens. However, Blinkers flash at normal speed but hyper-flash on dash after a couple seconds. I have done the hazard relearn several times and over 5 min. I have also done the ign-on hazard-on ign-off sequence and still have hyper-flashing. My '19 had no issue relearning but this '22 won't do it. I'm aware of the module to plug-in for hyper-flashing but that is intended to remedy the actual blinker hyper-flashing.
what say ye?
Old Oct 31, 2022 | 11:02 AM
White Ice's Avatar
White Ice
Buy LED's for H-D's from Custom Dynamics.
Old Oct 31, 2022 | 11:15 AM
kel03's Avatar
kel03
Try high beams off and on.
Old Oct 31, 2022 | 01:00 PM
propflux01's Avatar
propflux01
Turn on ignition. Turn on hazard lights. Leave hazards running for about 3-5 minutes. Shut off ignition. Shut off hazards. Should be good now. The canbus has to ‘adjust’ to the new load of the new lights.
Old Oct 31, 2022 | 04:54 PM
NoRegerts's Avatar
NoRegerts
I have Custom Dynamics. My left signal does that from time to time. The signals function, but the dash indicator blinks faster. I have done the relearn but it has not changed and I've called Custom Dynamics and they were unable to help.
I have found it's only under specific conditions it happens. I'm braking when I hit the left signal. If i signal, then brake it won't happen. Similar to yours, but what you're describing is it happens all the time?
I ran the cheaper Amazon LED lights for a while. I ended up riding home one night with only half my taillights working, as in the ring of lights became a mess of spots and ultimately died. I will never trust lights like that again and lesson learned. Custom Dynamics is expensive but worth every penny, especially considering it's a safety feature.
Old Oct 31, 2022 | 09:49 PM
Bafflingbs's Avatar
Bafflingbs
I have very expensive Eagle lights Sunburst turn/running lights, and they do the same thing. Just the dash. The lights are incredibly bright, so I’m learning to live with it
Old Nov 1, 2022 | 09:08 AM
shore's Avatar
shore
The dash hyper-flashes 100% when using the turn signals. They do not hyper-flash when using the hazards.
Old Nov 1, 2022 | 09:18 AM
shore's Avatar
shore
Tried it twice and this did not work for me.
Old Nov 1, 2022 | 09:31 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
On my bike each turn signal is powered individually. A CAN bus signal is sent to the speedo and from there power is sent to light up the dash. It could be a bug in the BCM,
Old Nov 1, 2022 | 02:29 PM
Eagle Lights's Avatar
Eagle Lights
Sponsor
On some models the indicator light will blink slightly faster. As long as the turn signals themselves are blinking at the correct speed, you have them installed correctly. Let me know if you have any other questions!
Thank you,
Keith
__________________
EAGLE LIGHTS - SEE AND BE SEEN
120 EAST AVE
SUITE 2E
NORWALK CT 06851
WWW.EAGLELIGHTS.COM
SUPPORT@EAGLELIGHTS.COM
1-800-921-3162
Use HDFORUMS for 15% off your entire order!
