Need advice before pulling the trigger...
Old Nov 9, 2022 | 12:41 PM
Medevack1's Avatar
Medevack1
Default Need advice before pulling the trigger...
So I have a 2008 Road King Police with 16" spoke wheels, I came across a nice set of take off enforcer 19" front and 16" rear wheels, rotors and tires. will this be a direct fit?
Old Nov 9, 2022 | 12:48 PM
NoRegerts's Avatar
NoRegerts
As far as I know, the axle changed in 2008, so your axles will fit. The next question is, did these come off an ABS bike and do you have ABS? I think 2008 was the first year for that too.
Edit: zooming in, looks like you have ABS. So the only limiting factor I can think of is if these have the ABS bearings.
Old Nov 9, 2022 | 01:04 PM
Fireball Jack's Avatar
Fireball Jack
Didnt the frame and swing arm change in 09. What year did the wheels come off of?
Old Nov 9, 2022 | 01:18 PM
Architect's Avatar
Architect
Those wheels look like they are from a much newer bike, including the cush drive for the rear wheel. Pretty sure '08 didn't have any of that.
Here is my simple method of checking year fitment.
Get yourself a HD Parts Catalog, the one the dealership gives away for free. Now look up a custom wheel they sell. It will clearly list the year range the wheel fits, lets say 2002 thru 2008. Now what year is your bike and what year was the bike the wheels came from? If they are both in the same range, you should be good. it works for me, good luck.
Old Nov 9, 2022 | 02:30 PM
NoRegerts's Avatar
NoRegerts
The frame changed in 2009, but I thought a 180 fits on the 2008 when the axle changed from 2007. 2008 is a weird year, but some things are more modern than the 2007's.
Checking the parts catalogue is a flawless way of determining fitment though.
https://www.hdforums.com/forum/touri...-sg-today.html
Old Nov 9, 2022 | 02:34 PM
Musician's Avatar
Musician
Architect, you would be mistaken. My '08 has the cush drive rear wheel. Bought it brand new with that wheel from the factory, plus the manual covers it. Biggest potential snag I see would be the ABS bearings. I believe the wheels are the same, so changing the bearings MIGHT be all that's needed. Also, check the rotor diameter. The '08 have 300 mm discs in front to fit the caliper location. Those look to maybe be larger diameter, and if so, they will NOT be compatible.
Old Nov 9, 2022 | 02:52 PM
NoRegerts's Avatar
NoRegerts
ABS bearings are more narrow on the side of the sensor. His bike appears to have ABS.
300mm is the equivalent of 11.8" which is the same from 2008 to today. The rotors will fit without adjustment. The bearing issue is all I see, as he has not responded as to whether the new wheels have the ABS bearing.
Old Nov 10, 2022 | 10:22 AM
seanl's Avatar
seanl
Rear wheel from 2009+ will not fit on a 2008 and older, they're quite different in width.
Old Nov 11, 2022 | 05:07 AM
MikeTD3's Avatar
MikeTD3
Although the 08 has a cush drive, it is a one year design.
trace2008
Oct 13, 2014 07:44 PM
highlanderque
Touring Parts
Jan 16, 2011 09:08 PM
calrickster
Oct 2, 2008 02:49 PM
diggitydogg
Dec 10, 2007 08:53 PM
mslater741
Aug 28, 2007 04:34 PM
