Tuner
Old Dec 4, 2022 | 12:30 PM
N8tivebro's Avatar
N8tivebro
Stage IV
Default Tuner
Hi folks..
I put vance and Hines slips on on my 2022 street glide and a cheap Amazon air intake and filter to replace stock one. Question is, do I need a tuner?
Old Dec 4, 2022 | 12:39 PM
Uncle Peepers's Avatar
Uncle Peepers
Wouldn't hurt. Anything to richen the mix a bit would help.
Old Dec 4, 2022 | 01:09 PM
N8tivebro's Avatar
N8tivebro
Stage IV
Default Tuner
Ok thanks
Old Dec 4, 2022 | 01:11 PM
hattitude's Avatar
hattitude
Do you NEED a tune...... no
Would you benefit from a tune.... yes
The M8 bikes aren't as lean in OEM form as the Twin Cam bikes were... so a Stage I retune isn't critical, but would help...
FWIW....
In '20 or '21 they changed the ECM... not sure if they changed the tune parameters at that time....
Prior tunes are only closed loop (with O2 sensor feedback) in part of the tune, mostly the cruising areas of the tune map. The rest of the tune is open loop, with no real time O2 sensor feedback. The open loop portion is in the high rpm, high load areas of the tune where AFR is most critical...
So if you are an aggressive driver and spend a lot of time in the high load and/or high rpm portions of your tune, you will be a little lean in those areas...
Old Dec 4, 2022 | 01:12 PM
N8tivebro's Avatar
N8tivebro
Stage IV
Default Tuner
But do I need it?
Old Dec 4, 2022 | 01:43 PM
N8tivebro's Avatar
N8tivebro
Stage IV
Thank you, that really helps going for and spending or not spending the money for one.
Old Dec 4, 2022 | 01:50 PM
MotoJockey's Avatar
MotoJockey
Basically, the MoCo puts the tune on their bikes that the EPA wants them to put on them, not what's best for the bike as far as being too lean and the bike not running at it's best performance level. If you want what's best for your bike, tune it.
Old Dec 4, 2022 | 03:08 PM
Redrodyankneck's Avatar
Redrodyankneck
Originally Posted by N8tivebro
Hi folks..
You replaced both air intake and exhaust so Yes you do need a tune. SE street tuner if you value 2 year warranty.
Air flow is a critical part of a properly running motor and keeping crap out of the intake is vital to its longevity. I could never see why anyone would but cheap parts on a new bike that is worth $$$$$.
Old Dec 4, 2022 | 06:18 PM
YZR's Avatar
YZR
But do I need it?
You were just told you don't NEED it.
Old Dec 4, 2022 | 11:10 PM
Silidons's Avatar
Silidons
Originally Posted by Redrodyankneck;[url=tel:20959662
20959662[/url]]You replaced both air intake and exhaust so Yes you do need a tune. SE street tuner if you value 2 year warranty.
the m8’s do not need a tune even with an air cleaner and exhaust. It’s not required. Will it run a little better, yes, but very minutely (less than 5%)
HighCountry
Jun 30, 2022 07:51 AM
Andrew Anderson
Sep 22, 2017 04:37 PM
Bruce00
2014-2024 Touring Models
Jun 29, 2017 02:39 AM
rockon
May 13, 2014 10:04 AM
VTL nut
May 27, 2010 06:32 PM
