Table Lift Loading Issue
Old Dec 27, 2022 | 10:04 AM
  #31
LQQK_OUT's Avatar
LQQK_OUT
Here's one of the pics I saved for when I decide to get motivated and do it....
Maybe you can get some ideas from this thread.
https://www.cvoharley.com/smf/index....ic=33651.0;all
Old Dec 27, 2022 | 10:05 AM
  #32
6113_'s Avatar
6113_
Originally Posted by Cle_rider
He did say in the opening post he wasn't interested in riding the bike up. Guess the current crowd just assumes the only reason to put a bike on a lift is routine maintenance?
Thanks Capt Obvious. Hadn't thought of that.
he also didn’t mention disabled motors either
c’mon January
Old Dec 27, 2022 | 10:14 AM
  #33
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No call for the snotty response.
OP, the only real option is to use a longer ramp to lessen the slope if yours is too steep without that earlier idea of digging out the floor to make the table flush with the ground.
Your idea is clearly not the only real option.
Old Dec 27, 2022 | 10:42 AM
  #34
theheder's Avatar
theheder
I drive my Streetglide and TriGlide on my Handy Lift with side extensions.
I also have the Trike ramp adapter that make the ramp wider at the rear and has wheel stops built into it.
Old Dec 27, 2022 | 11:27 AM
  #35
Dan89FLSTC's Avatar
Dan89FLSTC
What model Handy Lift do you have?
I have the SAM 1200, not sure if it would be ok for a Tri Glide (which will be showing up in my garage soon).
Old Dec 27, 2022 | 11:46 AM
  #36
Cle_rider's Avatar
Cle_rider
Got it, "snotty responses" are only permitted by you and should go unanswered if your intent was to take a pot shot at my attempt to answer the question.
But I meant that in jest. Clearly not the crowd for that.
Old Dec 27, 2022 | 05:27 PM
  #37
Ultra103's Avatar
Ultra103
I ride mine on. The table is it's home so it gets parked on there around 500 times a year.
Old Dec 27, 2022 | 05:42 PM
  #38
NorthWestern's Avatar
NorthWestern
You guys and your clean and tidy garages...
Old Dec 27, 2022 | 08:05 PM
  #39
hattitude's Avatar
hattitude
Mine's getting a little crowded.... but I think it's cozy....
Old Dec 27, 2022 | 08:36 PM
  #40
MRFREEZE57's Avatar
MRFREEZE57
I have the HF lift, mounted a Wheeldock chock on the front and made a couple walkways out of wood to put along side to put my feed down and just ride it up, works fine but sure would love to have one of those with side panels.
