HD ultra CVO 2017 reduce power
Old 01-11-2023, 01:19 PM
khalilalmarzooqi@gmail.com's Avatar
khalilalmarzooqi@gmail.com is offline
6th Gear
Default HD ultra CVO 2017 reduce power
Hi every one
I am having an issue with my Bike, HD ultra CVO 2017, power is reduced with no engine light indication,
so I had the famous problem with oil sumping and order a new oil pump and replaced it, ( oil pump for the newer models )
but what happens next, is that at some times the bike performs very well and has normal torque and power on it, but sometimes the engine while on the gear in Neutral, the rpm won't pass 4000 revs, and if I ride the bike for a short distance, the engine will be back to normal power,
anyone had this issue, do you think it still related to the sumping issue
many thanks
Old 01-11-2023, 01:26 PM
Ken45's Avatar
Ken45
Ken45 is offline
Have you looked to see if it is showing any fault codes?
Old 01-11-2023, 01:33 PM
6th Gear
Hi Ken,
I have checked the codes, and nothing out of ordinary, but to double check, I will post the codes later to review, however, the engine felt when this issue happened that it is ruining only with one cylinder, for some reason I suspect that the temperature management system kicks in for some reason, even though it should not,
Monkey7910
05-29-2022 08:23 PM
Edwardhead
Engine Mechanical Topics
06-19-2018 06:11 PM
DaytonaMark
Screamin Eagle CVO Models
13
04-01-2018 09:18 AM
paoloD
01-29-2017 08:02 PM
Hayhoss
12-25-2013 12:13 PM
Quick Reply: HD ultra CVO 2017 reduce power
