Tour pack quick detach on 21 / 22 Ultra Limited?
Old Mar 6, 2024 | 06:38 PM
  #41
Vultimate04's Avatar
Vultimate04
6th Gear
Originally Posted by Ssitruc
This^^^^
They pulled the kits because of the light's issue that is also in the kit... but like other have said piecemeal it together and you get what you want instead.
4-point Dock #52300353 $175
Tour Pack Mounting Bracket #53000221 $225
Run/Brake/Turn lights - I used CD's Fillerz $230
Tag Relocation Bracket - I used a curved CD one with a CD lit tag frame $120
Antenna(s) Relocation Bracket/Hidden Antenna(s) - #76000862 AM/FM $75 - I use that HD one and its works fine, but the reviews are missed on it.
Anyone here install the 4-Point Dock and TP Mounting Bracket part numbers on a 2017 Ultra Ltd FLHTK? When I look at those parts on the H-D website, it says they do not fit the 2017 Ultra Ltd FLHTK. Also says under Details, “Fits '14-later Touring models (except models equipped with rigid-mount Tour-PakŽ luggage and '24-later FLTRXSTSE).” If not these part numbers, then what numbers?
Old Mar 6, 2024 | 06:49 PM
  #42
Ssitruc's Avatar
Ssitruc
[QUOTE=Vultimate04;21596352]Anyone here install the 4-Point Dock and TP Mounting Bracket part numbers on a 2017 Ultra Ltd FLHTK? When I look at those parts on the H-D website, it says they do not fit the 2017 Ultra Ltd FLHTK. Also says under Details, “Fits '14-later Touring models (except models equipped with rigid-mount Tour-PakŽ luggage and '24-later FLTRXSTSE).” If not these part numbers, then what numbers?[/QUOTE
It is those part numbers, I used that stuff on my 2023 RGL myself... The reason it says that (the highlighted and embolden text in your quote) is because your bike currently has the "rigid mounted" tour pack, from the factory. Some of that stuff isn't for use with the rigid mount system... but you will be removing that rigid mount to make it "quick disconnect" mounted.... As dumb as it sounds, that is why it says that.
For instance, you can't put the 4 point dock, or the tour pack bracket on your bike, because the factory rigid mount is currently in the way... but when you get that factory stuff off and out of the way, all of a sudden there's magically room and a place to mount those two items I didn't design their website, just interpreting it.
Old Mar 6, 2024 | 06:59 PM
  #43
Vultimate04
6th Gear
I get what you’re saying. That would be a dumb way for them to say, the parts won’t fit with your current configuration, but if you remove the factory rigid mount TP hardware, these parts will fit. I mean the whole purpose for using these parts is to replace the current rigid mount base plate and integrated rails to achieve a detachable config. I’d like to see if someone here has actually had success using these on a ‘17 FHLTK. I suppose I can also call the stealer tomorrow too.
Old Mar 7, 2024 | 08:29 AM
  #44
Ssitruc's Avatar
Ssitruc
They'll work to do what you want to do (they are actually the parts to do that). But remember, all the touring bike's that do not come with factory tour packs, these same parts are how you would add a tour pack to them...
I guess it should say “Fits '14-later Touring models (Note: Models with rigid mount Tour-PakŽ luggage will require the removal of the factory rigid mount).”
Then what ever is applicable on the 2024 and later ST CVO...
Old Mar 9, 2024 | 07:25 PM
  #45
Vultimate04
6th Gear
Yeah, that should be it. Update: I ordered and installed the full conversion kit from Hogworkz. I had a little alignment issue with the rear dock points which I resolved by adding a 1/8” chrome spacer to each side that I got from Ace. I learned that even the H-D kit comes with an extra set of chrome spacers to resolve any potential alignment issues. The Hogworkz kit looks and works great.
Old Jul 24, 2024 | 09:46 PM
  #46
CJ11415's Avatar
CJ11415
Stage II
Default Has anyone used these parts list on a 2020 or newer?
This^^^^
I looked up a few of these parts in the Harley catalog, they say it won't fit a 2021. Anyone have any experience with these on a newer bike?
Old Jul 25, 2024 | 08:25 AM
  #47
Ssitruc's Avatar
Ssitruc
See post #42 above...
What bike are you working on?
I have a '23 RGL, and they work.
Old Jul 25, 2024 | 08:35 AM
  #48
CJ11415's Avatar
CJ11415
Stage II
I have a 2021 Ultra Limited. FLHTK.
Old Jul 25, 2024 | 02:04 PM
  #49
Ssitruc's Avatar
Ssitruc
The catalog or web page I guess it should say Fits '14-later Touring models (Note: Models with rigid mount Tour-PakŽ luggage will require the removal of the factory rigid mount).”
It is those part numbers, that I used on my 2023 RGL myself... The reason the catalog says that is because your bike currently has the "rigid mounted" tour pack, from the factory. Some of that stuff isn't for use with the rigid mount system... but you will be removing that rigid mount to make it "quick disconnect" mounted.... As dumb as it sounds, that is why it says that.
For instance, you can't put the 4 point dock, or the tour pack bracket on your bike, because the factory rigid mount is currently in the way... but when you get that factory stuff off and out of the way, all of a sudden there's magically room and a place to mount those two items I didn't design their website catalog, just interpreting it.
Old Jul 28, 2024 | 01:31 PM
  #50
bigal51's Avatar
bigal51
I had a kit put on my 2024 RG LAST February.
dlrshort
Jan 6, 2023 09:20 PM
kevin Z06
Jul 27, 2022 04:26 PM
flattracker60
Feb 2, 2014 06:19 AM
C908
Jul 2, 2012 08:32 AM
shootdonniebrook
Apr 5, 2012 07:17 PM
