Help! Blowing fuses.
Old Aug 22, 2007 | 06:42 AM
MX10RS's Avatar
MX10RS
Default Help! Blowing fuses.
I keep blowing the fuse for my brake lights. Just as soon as I turn the switch on the fuse pops. First the speedo and tach went out, but that is ok now, but this one keeps it up. I have checked for bare wires, loose wires etc, but so far nothing. Any ideas?
Old Aug 22, 2007 | 06:49 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: Help! Blowing fuses.
Check under the seat to make certain that the bubdle of wires running to the tail light have not been pinched
Good Luck
Ride Em Carry Em
Old Aug 22, 2007 | 07:06 AM
TexasRedneck's Avatar
TexasRedneck
It'd be a TAD helpful ta KNOW what we're tryin' ta troubleshoot here....'07 UC, '02 Sporty, Edsel.....
Bottom line, ya gotta trace the wire harness - most likely it's from a rub or pinch point - check the harness path on the way to the tail light!
Old Aug 22, 2007 | 07:30 AM
G$'s Avatar
G$
From: LexVegas, KY...home of fast wimmen & beautiful horses
Have u done any mods lately? Is it a new bike? Details........Details......
Old Aug 22, 2007 | 07:42 AM
larry5h's Avatar
larry5h
Need all details
Old Aug 22, 2007 | 08:20 AM
NICK56's Avatar
NICK56
do u have heated grips?? if so check ur wires there...A buddie of mine had the saem issues . his problem was a pinched wiore near the grips!
Old Aug 22, 2007 | 08:29 AM
SG Mike's Avatar
SG Mike
Details please...
Old Aug 22, 2007 | 11:22 AM
SteveO's Avatar
SteveO
If you chenged grips sounds like you pinched a wire. Got to be real carefull when putting the grips on. I did the same thing.
Steve
Old Aug 22, 2007 | 11:30 AM
drdiesel1's Avatar
drdiesel1
You could have a short in the tail-lamp socket as well. You need to isolate the fault. Unplug the tail lamp at the rear fender and see if it still blows the fuse. If not trace it fromthe plug to the lamp.
If it still blows the fuse, unplug the brakeswitch(s) one at a timeand retest. It`s a process of elimination. You could also have any-other lamp ETC that`s on that circuit causing this failure, not just brake thelamp.
Old Aug 22, 2007 | 03:15 PM
Harleypingman's Avatar
Harleypingman
Gold Wing, John Deere???
