Bringing Touring model to a stop
Old Apr 24, 2023 | 02:40 PM
Tcrafty's Avatar
Tcrafty
All good info shared.
I might also add, I've got the same issue. Although, I don't believe my issue is with which brake is used. I think the neck bearings in my Springer have some wear. When I slow down, if I try to adjust ever so slightly, it's like the bars get "notchy" and I overcompensate. Then I need to re-adjust the other direction and guess what happens.
It's definitely not life-threatening or anything, but it does kinda make you look like you're trying to figure out how to stop. I'll be doing the maintenance on my springer front end soon, so that'll be another area to check. I don't think the fluid forks would be any different. You might want to consider checking them (or maybe you've noticed a similar notchiness).
I just mention this as it may also help others who run into the same issue but changing braking patterns don't help. My .02 and change will be given back if necessary. YMMV
Old Apr 24, 2023 | 02:42 PM
CJ250's Avatar
CJ250
I also experienced this on my Road King (the nose dive when breaking made it hard to stop smoothly sometimes) until I swapped out the stock front fork springs for Legend axes cartridges. This eliminated the braking issues for me altogether.
BTLorys's Avatar
BTLorys
Originally Posted by M Oclaf
Don’t listen to half the horseshit posted, stop over thinking it. Just brake like you always have.
If braking like he always has is causing him issues, why would he keep doing the same thing over and over?
Old Apr 24, 2023 | 02:50 PM
702's Avatar
702
Just so he knows... which half?
Old Apr 24, 2023 | 03:12 PM
Rob175's Avatar
Rob175
I always use BOTH front and rear brakes to stop because I was taught that way. Once I slow down to "a walk" I ease up slightly on both.
The "linked" braking system on the newer HD's only "kicks-in" at speeds above about 20mph. Once you release either brake below 20mph and then re-engage a brake (front or rear) the linking system won't "kick-in".....you need that awareness.
As often heard "It takes no skill to go fast, in a straight line...but, it takes practice to master being skilled at slow speed."
Old Apr 24, 2023 | 03:26 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Redlegvzv
The bike is not easy to smoothly stop…it sort of totters along once it is below around 5MPH. Then it is a race between instability of the bike below 5MPH and getting your feet down.
If I’m understanding you correctly, you’re trying to creep along at the end before fully stopping. That can be tough to do.
Might I suggest you target your stopping so you don’t have to creep along. I’m not talking about stopping short, just less creeping and tottering. Simply come to a smooth, creepless, stop.
Old Apr 24, 2023 | 03:34 PM
M Oclaf's Avatar
M Oclaf
He’s stated no issues on prior bikes, and that leads me to believe he is overthinking it. Not sure of the post but the one about just bringing to a smooth stop, right foot brake, left foot down, right hand brake hold/stop, right foot down but occasionally it’s not fluid, but 9 out of 10 times it’s just that simple. Just brake. Don’t think of the process, just do it? And a slight stop with front brake won’t make you drop the bike. Full turn on bars and brake lock, no doubt. Slight turn, slowed speed as in practically stopped, bike is stopping. Not dropping. Add to that, linked brakes, front is activated as it is, no such thing anymore on a new Harley as rear or front only. I still believe he’s overthinking it. Just ride and react as one does.
Old Apr 24, 2023 | 03:36 PM
Keithhu's Avatar
Keithhu
Originally Posted by 702
His 2018 Road King has linked brakes, so using rear pedal only also activates the front brakes. Seems way safer than what Mr. Jerry recommends.
From the 2020 owners manual (not sure if it's different in 2018)
"At speeds greater than 7 km/h (4 mph), the system dynamically adjusts the linking for the amount of brake applied as well as vehicle speed to achieve an optimized brake balance. The system provides more linking when the rider is applying heavier braking and reduces or eliminates linking for light braking and low speeds."
"At speeds less than 3 km/h (2 mph), the brakes are not linked so that low speed maneuverability is not adversely affected, such as when riding the motorcycle in a parking lot."
Old Apr 24, 2023 | 03:47 PM
702's Avatar
702
It's my understanding that if I depress the rear pedal and do not release the pedal they stay linked? Is my understanding incorrect?
Old Apr 24, 2023 | 03:50 PM
Keithhu's Avatar
Keithhu
Direct quote from the owners manual
